Emax
Internal SCSI connection in EMAX II
1999-11-03 by auer@...
Is the internal SCSI connector for the EMAX II a standard DB50?
It looked a little longer than the internal connector in my mac.
 Also, should one of the center pins on the board side be missing?
I have an internal drive on the way and want to
get the correct cabling for it, or be buying an external case for it.
Thanks in advance,
Ed
Re: Internal SCSI connection in EMAX II
1999-11-04 by Henrik Nydell
It is a standard 50 pin SCSI internal. One HDD i can recommend w EmaxII is
the Quantum Maverrick 540. I have two of them installed internally in my
EmaxII. There is only one power cable inside, so youll have to get an
y-cable if youre gonna use more than one internal drive. The EmaxII power
supply seemed to be a bit cheesy so i switched it for a more powerful
PC-supply
About that missing pin i know nothing... Is it missing in the
SCSI-connector? I know that some IDE connectors lack one pin. Thus
preventing inserting the cable wrong.
/Henrik
>Thanks in advance,
>Ed
>>Emax and Emax II User's Group
>http://www.ncal.verio.com/~qsite/emax
1999-11-13 by Ed Auer
Thanks for the info I successfully installed a Cooner 540 drive.
How did you mount your drives inside the emax? Hardware from a
pc mounting kit?
thanks -e
At 08:16 PM 11/4/99 +0100, you wrote:
>From: Henrik Nydell <nyd@...>
>PC-supply
>/Henrik
>>Thanks in advance,
>>Ed
oops, that was a conner 540 drive.
-e
At 08:14 AM 11/13/99 -0500, you wrote:
>From: Ed Auer <auer@...>
>pc mounting kit?
>thanks -e
>>PC-supply
>>/Henrik
>>>Thanks in advance,
>>>Ed
1999-11-13 by Henrik Nydell
I have mounted my two 540's as follows:
Wrapped them into thick packaging plastic and thrown the pack right in and
reassembled the Emax case.. :) Not a very nice solution but they have been
running for two years now, withouth problems. There might be a problem of
overheating though, but I have never had my Emax on for more than a day or
so at a time.  There are plenty of room inside, so there is no good reason
for _not_  mounting the drives properly. (Maybe w a PC kit) but I'm too lazy.
>-e
>>pc mounting kit?
>>thanks -e
>>>PC-supply
>>>/Henrik
>>>>Thanks in advance,
>>>>Ed
