Disklavier
Index last updated: 2026-04-28 23:20 UTC
Lost music on Yamaha Disklavier
2014-06-02 by herblindahlpianotuning@...
I thought I would resend this message from February, 2014. My client is still looking for help. He realizes it is a longshot but he was hoping there was some chance to recover some of his recordings. Several of you were kind enough to respond,but I am not sure if there was any other thoughts from the group.
Thank you.
Herb Lindahl
On Feb 7, 2014, at 4:00 AM, >>>> > wrote:
>>>> Greetings to the group from Connecticut. My name is Herb Lindahl and
>>>> I have been in the Piano Tuning and Restoration business for 30
>>>> years. I have a client here in CT with a Disklavier with the
>>>> DKC55rcd Control unit. He has owned it about ten years. He has made
>>>> many recordings of himself playing over the years. Recently, his
>>>> young daughter was recording herself playing, and while the song was
>>>> saving to a memory disk, she, by accident shut the unit off. Now my
>>>> client cannot access any of the music he had stored on the unit. Is
>>>> there a way to restore his music, or could it all be lost ?
>>>> Thank you in advance,
>>>> Herb Lindahl
>>>> 860-644-9407
Re: [disklavier] Lost music on Yamaha Disklavier
2014-06-02 by Spencer Chase
what do you mean by a memory disc? is this a flash drive of some type?
if you disconnect (or turn off power) while the directory is being
updated you can end up with an unreadable device. there is software that
can restore a directory as long as nothing has been added to the drive.
there are also companies that recover data from just about anything but
it is usually expensive.
> Thank you.
> Herb Lindahl
> >>>> Herb Lindahl
> >>>> 860-644-9407
Best regards, Spencer Chase
67550-Bell Springs Rd.
Garberville, CA 95542 Postal service only.
Laytonville, CA 95454 UPS only.
Spencer@...
http://www.spencerserolls.com
(707) 984-8356
(425) 791-0309
2014-06-03 by Mark Fontana
Unless Yamaha has any recovery tools or a utility to extract a raw dump
of the memory disk storage, I think the only way to proceed would be to
send the Disklavier control unit to a data recovery specialist or
company like Kroll Ontrack.  That individual or company would need to
desolder the flash chip(s) holding the memory disks, dump them using an
external reader/programmer, repair the file structure (if anything can
be salvaged at all), extract the files, then reinstall or replace the
flash.  This will be very expensive.
The job can be divided into two tasks.  The first task would be to
obtain the dump of the flash memory and reassemble the controller; the
second task would be to study the dump and piece together any recordings
that are still intact.  As the latter task requires some knowledge of
Disklavier file formats, I would be willing to take a shot at recovering
performances from a raw dump of the flash memory, if your customer can
obtain that.  It would be less expensive than paying a data recovery
service to come up to speed on these.
I have not seen the inside of a DKC55RCD.  If the flash memory is
socketed or otherwise removeable, that would make the job of obtaining
the dump much easier.
Mark Fontana
> Thank you.
> Herb Lindahl
> >>>> Herb Lindahl
> >>>> 860-644-9407
