Stero version of CGS 202 resonant eq
2013-04-01 by adematteo
Hey guys, I would like to build a stereo version of the res. eq.
The idea would be to build a desktop box that i can run my master bus from my mixer through.
I was wondering if anyone could offer any practical advice as far as getting close to the same response from both boards ?
At first thought i was going to use dual gang pots but then have read the tolerances between the 2 sections can be 10-20 % different.
Do you guys know of any other affordable solutions ?
I assumed to match all the caps in the filter sections.Other than that and the pots i figured this should be doable for a reasonable cost but maybe i'm dreaming ?
Thanks for any insight you guys can share.
-Tony
-Tony
