Archive for Simmons_Drums.
Index last updated: 2026-03-30 01:08 UTC
Is this an SDSV?
Re: Is this an SDSV?
2014-07-01 by alfpaches@...
Toms absolutely SDSV
About the snare, I´ve seen this concert a lot of times but I´m not sure. I think it´s not from a SDSV.
Re: [Simmons Drums] Is this an SDSV?
2014-07-01 by jesper
jose_sds8@... [Simmons_Drums] skrev 2014-07-01 01:08:
> Hi mates
> https://www.youtube.com/watch?v=vNpbsPfaZEE
> I'm trying to get that sounds with an SDSV but i don't how to do it.
> What effects could have that snare? toms?
> Regards.
YMO used a lot of other drum synths as well. Most known are the
Ult-Sound DS-4 and I think that is a better candidate for the snare
sounds here.
electronically yours, jesper
www.electronic-obsession.se
Angaudlinn on iTunes:
https://itunes.apple.com/us/artist/angaudlinn/id582356650
Angaudlinn on Amazon:
http://www.amazon.com/s/ref=ntt_srch_drd_B00AI3LNNM?ie=UTF8&field-keywords=Angaudlinn&index=digital-music&search-type=ss
Angaudlinn's playlist på Spotify:
http://open.spotify.com/user/simplyanalogue/playlist/540Srd3zA15pK7G1S8qLHo
Angaudlinn on facebook:
https://www.facebook.com/Angaudlinn
2014-07-01 by JenkinsC01@...
The equipment list for the 1983 album BGM lists Pollard equipment as well as Ult-Sound, so it may have been a Syndrum (but they tend to be better for quirky effects than for snares).
Re: [Simmons Drums] Re: Is this an SDSV?
JenkinsC01@... [Simmons_Drums] skrev 2014-07-01 14:06:
I have a Syndrum Quad and used to own a Ut-Sound DS-2, but maybe Thomas
can enlighten us. I think he has both (and tonnes more).
BTW, Syndrums and good for snares too. It just depends on the snare
you're after. :D
2014-07-01 by Thomas Heckmann
Hi guys,
the snare and toms are SDSV in my opinion and I can get the sounds easily with mine and they are classic sounds.
Not sure about the bassdrum, but I cannot see the rack or brains of Takahashi.
Keep in mind they mixed the sound of the venue with the recordings, so you get unusual reverbs.
Also keep in mind that the SDS V sounds different when played with the original riot shield pads then using
it with triggers from a drummachine i.e.
They used ULT-4s in previous pre Simmons years and you can usually see all the ULT pads with Takahashi easily.
Hope that helps :-)
Best,
Thomas
Thomas P. Heckmann
Trope Recordings - Trope Mastering - AfuLimited - AFULAB
On Jul 1, 2014, at 1:08 AM, jose_sds8@... [Simmons_Drums] wrote:
Hi mates
I'm trying to get that sounds with an SDSV but i don't how to do it. What effects could have that snare? toms?
Regards.
2014-07-01 by Nick Zampiello
i think there is a drum machine on the side by the fan.  table top with a sloped top.  not likely an SDS5.  i hear linn sounds and other sounds maybe it's an SDX off stage? or sampler?
NEW ALLIANCE EAST!!!!
New Alliance East - Mastering
New Alliance East - Facebook
X :::: B :::: S
On Tuesday, July 1, 2014 8:58 AM, "Thomas Heckmann troperecordings@... [Simmons_Drums]" <Simmons_Drums@yahoogroups.com> wrote:
Hi guys,
Hope that helps :-)
Best,
Thomas
Thomas P. Heckmann
Hi mates
Regards.
2014-07-02 by paistekid@...
Just wondering if anyone here has any tips on how to fix the triggering component for my SDSV pads.  It seems the sensitivity of the surface no longer works.  Is it something that can be replaced electronic-wise?  I really don't want to get rid of the pads because of this reason.  SDSV pads are rare these days especially the ones in blue color.  Any info is greatly appreciated!
2014-07-02 by jesper
If it's "just" the pad that is wacko, I'd open it and check if the piezo
element has died. Piezos are cheap and easy to find. They basically
generate a voltage that is larger if you hit harder (i e louder).
Don't trash anything 'cause it's dead. The electronic parts inside a pad
can easily be counted. 1-2-3?
If you mean that there are problems at the other end (verifying this
with other pads etc) it can be trickier, but everything can be repaired.
It's not rocket science.
paistekid@... [Simmons_Drums] skrev 2014-07-02 03:09:
2014-07-06 by paistekid@...
Hello Jesper,  I unscrewed and removed the edge but noticed the surface cemented to the plywood.  This will not come off without the use of tools to lift it up and I am worry i might damage or better yet crack it.  After all it's been 30 plus years since someone opened it!  The surface has to be removed to access the wiring.  Have u ever opened one of these before?
Thanks.
2014-07-08 by superwolle70@...
Don't remove the playing surface! The transducer is glued under the bottom side of the plywood, so you need to screw of the bottom shell to access/replace the piezo
2014-07-08 by jesper
superwolle70@... [Simmons_Drums] skrev 2014-07-08 15:03:
What Wolfgang said ^^^^^^^ :)
superwolle70@... [Simmons_Drums] skrev 2014-07-08 15:11:
> Here are pictures of a complete restoration of "a piece of junk". It's
> in German but the pictures will give you an idea what's happening inside
> http://www.drummerforum.de/forum/36496-wolle70-minimal-auf-seite-22/thread17.html#post1078756
"Was sich da offenbarte grenzte an biologischen Kampfstoff."
:D It certainly looks dangerous in the images! :D
"könnte man im Notfall auch noch als Vogelbad oder Salatschüssel nehmen"
I think a frosted set with mounted LEDs inside so that it lights up upon
hit would've been cool. 80's cheesy?! I don't care!
2014-07-08 by Nick Zampiello
what did he use to remove the paint.  i want clear pads!
X :::: B :::: S
On Tuesday, July 8, 2014 9:47 AM, "jesper jesper@... [Simmons_Drums]" <Simmons_Drums@yahoogroups.com> wrote:
