Simmons SDS 1000 & MTM
2013-04-23 by HH
Index last updated: 2026-03-30 17:31 UTC
2013-04-23 by HH
2013-04-23 by Ed
--- In Simmons_Drums@yahoogroups.com, "HH" <grandedoot@...> wrote:
> Hello again!
> I have a SDS 1000 & am wondering if a MTM system would work with it? The SDS is nice, but I have visions from the 80's when I would go to a keyboard store & they had either the SDX (or the MTM) that could be played & it was AMAZING!
> If the MTM adds a ton of incredible sounds to the SDS 1000, I suppose, I'm super curious to know.
> Thanks guys & gals! Chris
2013-04-23 by HH
--- In Simmons_Drums@yahoogroups.com, "Ed" <edrose1@...> wrote:
> Hey Chris.
> MTM is a MIDI interface and does not produce sound. It translates audio and trigger signals into MIDI data and MIDI data into trigger signals to drive non-MIDI modules like SDSV and SDS7. It's an amazing device - even by today's standards - and highly recommended if you want to get way out there triggering synths from pads via MIDI or adding MIDI delay to your SDS1000. If you're just looking to add MIDI capability to your SDS1000, it may be overkill.
> Ed
> --- In Simmons_Drums@yahoogroups.com, "HH" <grandedoot@> wrote:
> > Hello again!
2013-04-23 by Michael Buchner
> Hey Chris.[Non-text portions of this message have been removed]
> Ed
> > Hello again!
2013-04-23 by Nick Zampiello
2013-04-23 by HH
--- In Simmons_Drums@yahoogroups.com, Nick Zampiello <newallianceeast@...> wrote:
> your SDS1000 doesn't have midi?
> many do and if you get one with midi you don't need an MTM>
> z
> Â
> NEW ALLIANCE EAST!!!!
> New Alliance East - Mastering
> New Alliance East - Facebook
> X :::: B :::: S
> From: HH <grandedoot@...>
> To: Simmons_Drums@yahoogroups.com
> Sent: Tuesday, April 23, 2013 10:58 AM
> Subject: [Simmons Drums] Simmons SDS 1000 & MTM
> Â
> Hello again!
2013-04-24 by jesper
> Thanks Nick,Often the midi socket marked in is a dead giveaway. :)
> How the H do you know if it has a midi or not?
2013-04-24 by Nick Zampiello
> z
> Â
> X :::: B :::: S
> Â
> Hello again!
> there's a spot for midi in and out on the back.Please include links instead. I've disabled inclusion of attached files
> this pic from google has no midi. you can see the round ports on the
> back are covered over:
> SDS1000nomidi
2013-04-24 by brian walker
> z
> Â
> X :::: B :::: S
> Â
> Hello again!
2013-04-25 by Nick Zampiello
> z
> Â
> X :::: B :::: S
> Â
> Hello again!
2013-04-25 by brian walker
> z
> Â
> X :::: B :::: S
> Â
> Hello again!
2013-04-25 by Michael Buchner
> Hi[Non-text portions of this message have been removed]
> There is a whole pile of components missing
> Now I know exactly what they are
> Originally thought about rebuilding / copying the missing parts from the SDS1000M
> Having acquired a SDS1000 that had MIDI I have not bothered
> I might give it a try now
> Brian
> From: Nick Zampiello <newallianceeast@...>
> To: "Simmons_Drums@yahoogroups.com" <Simmons_Drums@yahoogroups.com>
> Sent: Thursday, 25 April 2013, 6:59
> Subject: Re: [Simmons Drums] Re: Simmons SDS 1000 & MTM
> the one i have has midi and works great.
> it's hard to believe they would have SDS1000's in the world with MIDI jacks but no midi.
> are you one the wrong midi channel? it defaults to channel 1.
> also, it only plays sounds on keys 60, 62, 64, 66, 68
> PS, i found instructions for adding midi to a 1000:
> don't remember where i got these, i never did the mod myself.
> Install the following parts:
> R5, R6, R7 - 220R resistors
> R17 - 390K resistor
> R18, R19, R20 - 8M2 resistors
> R177, R182, R250, R251, R252 - 270K resistors
> R246 - 220K resistor
> R262, R263, R264, R265 - 1K0 resistors
> R266, R267, R268, R269 - 2K2 resistors
> C9, C10, C11, C12 - 1n0 capacitors
> C30, C44, C58, C78 - 0.1uF capacitors
> D42, D43, D44 - each 3 x 1N4148 diodes in series
> (mount two sticking vertically out of the board and
> one across the top)
> D54, D64, D65, D66, D67, D68 - 1N4148 diodes
> D57 - BAT85 schottky diode
> IC6 - 74LS14 hex inverter
> IC7 - 4N28 optoisolator
> IC16 - LM324 quad opamp
> P11, P12 - 8 pin DIN sockets, pcb mounting
> L1 - wire link in 0v position
> L2 - wire link in +5v position
> There is also a 470R resistor suggested between
> pins 4 and 14 on IC6. There was a space on the
> circuit board for mine, but on some versions you
> may have to solder the resistor on top of the chip.
> z
> X :::: B :::: S
> From: brian walker <brian1075us@...>
> Sent: Wednesday, April 24, 2013 1:38 PM
> Hi
> I have an SDS1000 and a SDS1000m
> They both have a full set of 5 pin DIN sockets and working MIDI
> I have seen a SDS1000 without the sockets so NO MIDI
> I have also seen a SDS1000m with a full set of 5 pin DIN sockets but with NO MIDI functions
> I am still trying to figure it out
> If it has a 5 pin DIN socket plug a MIDI lead into it and see what you get
> The results will be: -
> It works fine
> It does not work in which case: -
> It is NOT MIDI capable
> OR
> It is MIDI capable but is not working properly
> Hopefully that covers all eventualities
> Brian
> Sent: Tuesday, 23 April 2013, 23:50
> Subject: [Simmons Drums] Re: Simmons SDS 1000 & MTM
> Thanks Nick,
> c
> > z
> > Â
> > X :::: B :::: S
> > Â
> > Hello again!
> Brian
> R17 - 390K resistor
> one across the top)
> z
> X :::: B :::: S
> Hi
> It works fine
> OR
> Brian
> Thanks Nick,
> c
> > z
> > Â
> > X :::: B :::: S
> > Â
> > Hello again!
2013-05-17 by philmurr
--- In Simmons_Drums@yahoogroups.com, Michael Buchner <buchnerelectronics@...> wrote:
> I am not "into" the 1000 in the moment, but I remind, that with fitted midi parts the software (Eprom) had to be changed. I have a midi 1000, check you version (on the software Eproms top), then we know more. If somebody is interested in different snare sounds, I can sell some Eproms for the 1000 too...
> Von meinem iPhone gesendet
> Am 25.04.2013 um 09:14 schrieb brian walker <brian1075us@...>:
> > Hi
> > Brian
> > R17 - 390K resistor
> > one across the top)
> > z
> > X :::: B :::: S
> > Hi
> > It works fine
> > OR
> > Brian
> > Thanks Nick,
> > c
> > --- In Simmons_Drums@yahoogroups.com, Nick Zampiello <newallianceeast@> wrote:
> > > z
> > > Ã
> > > New Alliance Eastà - Mastering
> > > New Alliance Eastà -à Facebook
> > > X :::: B :::: S
> > > From: HH <grandedoot@>
> > > Ã
> > > Hello again!
2013-05-17 by Michael Buchner
Sent: Friday, May 17, 2013 1:47 PM
I opened up my SDS1000 (non-MIDI) last night and it doesn't have an additional EPROM for the program, just one for the snare sample. It uses an 8051 (with built-in ROM) rather than the 8031 that most of the other Simmons units use.
So in this case I guess I couldn't upgrade mine to MIDI ?
> > Hi
> > Brian
> > R17 - 390K resistor
> > one across the top)
> > z
> > X :::: B :::: S
> > Hi
> > It works fine
> > OR
> > Brian
> > Thanks Nick,
> > c
> > > z
> > > Ã,
> > > New Alliance EastÃ, - Mastering
> > > New Alliance EastÃ, -Ã, Facebook
> > > X :::: B :::: S
> > > Ã,
> > > Hello again!
