Lucky you
Berk
>-- Oorspronkelijk bericht --
>To: <Simmons_Drums@yahoogroups.com>
>From: <jesper@...>
>Date: Mon, 13 Aug 2007 11:02:53 +0200
>Subject: Re: Re: [Simmons Drums] SDS-8 voltage again
>Reply-To: Simmons_Drums@yahoogroups.com
>Looks like the seller dug out the original transformer... I'll meet with
>him
>later this week. Then I'll get a homemade bass drum trigger too... :)
>electronically yours, jesper
>www.electronic-obsession.se
>Order your own copy of the Machinepop/Imiafan
>split-EP at www.electronic-obsession.se/label.asp
>"Varför har du så många pianon?" (Nora Persson, 9 år)
>----- Original Message -----
>From: "Berk Aarts" <B.E.R.K@...>
>Sent: Wednesday, August 08, 2007 9:48 AM
>Subject: Betr: Re: [Simmons Drums] SDS-8 voltage again
>Depends on what the rest is behind it
>If the current is stabilazed by an IC ( like an 915) it can be increased
>a few volts ( up to 21V perhaps)
>if not than it's supposed to work on 15 V as well ( and that's a much easier
>kind of transformer t find I guess)
>good luck
>Berk
>>From: <jesper@electronic-obsession.se>
>>Date: Mon, 6 Aug 2007 20:19:58 +0200
>>Subject: Re: [Simmons Drums] SDS-8 voltage again
>>That's the P, AC + AC + Ground. I thought LJ had an idea but he didn't
>>remember and Michael is on it as I write.
>>I wonder how exact it want those 18 volts...
>>Sent: Monday, August 06, 2007 7:31 PM
>>Subject: Betr: [Simmons Drums] SDS-8 voltage again
>>Hi Jesper
>>I tought they are on the group??
>>If you're sure it's 18 V AC then find out what the ground is and the other
>>are the 18 V pins
>>But is not 18 DC with + and - ???
>>good luck
>>Berk
>>>From: <jesper@...>
>>>Date: Mon, 6 Aug 2007 12:50:05 +0200
>>>Subject: [Simmons Drums] SDS-8 voltage again
>>>Hi List!
>>>Does anyone here have the schematics for the SDS-8? Mine was sold with
>>>external PSU which now is lost and I need to sort out how to wire the
PSU.
>>>It wants 2x18 volts AC and ground.
>>________________________________________________________________________________________
>>12move ADSL: Voordelig, snel en onbeperkt internet.
>>Meer informatie vind je op http://adsl.12move.nl
>>Yahoo! Groups Links
>>Yahoo! Groups Links
>Yahoo! Groups Links
>Yahoo! Groups Links
