Triggering MIDI with Simmons Pads
2006-10-26 by neilvoss
I'm looking at picking up an SDSV kit/brain but would also like to be able to trigger MIDI based sounds with the pads (probably samples or routing into a laptop to control a VSTi or emulated synthesis). Is it possible to use these pads as conventional triggers with other audio hardware like, for example, the recent or new alesis converters? I've spotted older simmons-made trigger-to-midi converters on ebay, but I assume if it works on any sort of standard it would be better to just get a newer/smaller piece of kit... Thanks and sorry if this is a redundant topic! - Neil
