Protecting copper surface(newbie)?
2003-09-18 by sogilo
2003-09-18 by Stefan Trethan
On Thu, 18 Sep 2003 07:11:42 -0000, sogilo <sogilo@...> wrote:
> I am trying to bake my first PCB, the thing is I don't know how to
> protect copper surface. Some says " Sprayed with a thin coat of clear
> lacquer" but my application requires high current(200A) flow and i
> doubt that lacquer will do the job.
> Be sure to visit the group home and check for new Bookmarks and files:
> Homebrew_PCBs-unsubscribe@yahoogroups.com
2003-09-18 by wheedal99
clear
2003-09-19 by Adam Seychell
2003-09-19 by Dave Mucha
> I am trying to bake my first PCB, the thing is I don't know how toclear
> lacquer" but my application requires high current(200A) flow and iIf I read your post correctly, 200 amps ?
2003-09-19 by Stefan Trethan
> --- In Homebrew_PCBs@yahoogroups.com, "sogilo" <sogilo@y...> wrote:I fear we get no more information on this. just like Markus and his patent
> clear
> I don't think the COPPER will do the job.
> or, you got one heck of a trace there.
> As far as protecting the copper, spray laquor is to keep it from
> tarnishing.
> if you want an all weather protector, be aware that the heat from a 200
> amp trace may burn off most everything unless you are using some pretty
> thick and wide traces.
> Dave
2003-09-21 by Don Perry
> @Dave
> thanks for the tip with laquer thinner for solving colophony resin.
> i tried it and it is much better than alcohol.
> The "laquer" is the same density / concentration in the whole jar, it stays
> good dissolved without stirring etc.
> with alcohol it was always thicker at the bottom (with acetone too).
> Dries quick and leaves a shiny coat.
> I actually tried it as a resin for etching (because the quality is much
> better now).
> The problem is the plotter pens i have (carbide tipped) don't leave a thick
> enough layer to resist HCl H2O2.
> I will try repeated plotting and maybe try Fe3Cl which i have standing
> around somewhere (Does it decay in a sealed Bottle?).
> But i applied it with a piece of wire and with a piece of a paper towel
> "disposeable brush with needle-nose pliers handle).
> And this areas resisted the etching very well.
> So i think the plotter pens simply make a too thin layer.
> any ideas? - would be great to solder the boards with resin layer and also
> protection against corrosion.
> st
2003-09-21 by Stefan Trethan
On Sat, 20 Sep 2003 21:06:55 -0400, Don Perry <mojo@...> wrote:
> Here's what works for me, I use a HP 7475 pen plotter with a slot cut in
> the
> case. I use a GC #22-222 Etch Resist Ink Pen. 1/64 " tip. Its fitted
> into a
> drilled and honed out dried up HP pen. I have to keep etching fast. I
> heat Fe
> CL3 on my grill outside, in a oven dish. Wear glasses, gloves, and
> apron. I
> use a oven baster to spray the center of the project. The edges seem to
> eat
> off first and I keep the acid going to the board center. This is not a
> time to
> walk off and come back. I keep an eye on the board till it is complete.
> You
> can always put it back in, but once its eaten the copper away its done.
> Stefan Trethan wrote:
>> @Dave
>> stays
>> better now).
>> thick
>> also
>> st
2003-09-26 by Don Perry
> which tip has this pen?
> which color has the ink?
> maybe i really have to search this bottle of fe3cl... and then try
> different inks.
> The problem with using pens directly for me was that line with varies with
> speed.
> at the corners the pen slows down and the line with increases.
> i didn'tlike this, the were small tears at both sides of each corner.
> don't you have this problem with the resist pen?
> st
> > the
> > into a
> > heat Fe
> > apron. I
> > eat
> > time to
> > You
> >> @Dave
> >> stays
> >> better now).
> >> thick
> >> also
> >> st
2003-09-26 by Stefan Trethan
On Fri, 26 Sep 2003 09:05:57 -0400, Don Perry <mojo@...> wrote:
> I have the plotter running - slow. And I always add angle to each 90 deg
> trace
> in the artwork. A short trace placed in the inside corner of each trace.
> The
> angle is the shortest one that fits for the trace width. That helps and
> touchup
> after plotting does too. I also sometimes keep the pcb in the plotter
> after
> its done, and replot after it has dried 15-20. That CG pen I use doesn't
> seem
> to scrape ink off on retracing.
>> different inks.
>> with
>> speed.
>> st
>> in
>> > the
>> fitted
>> > into a
>> > heat Fe
>> > apron. I
>> to
>> > eat
>> a
>> > time to
>> complete.
>> > You
>> done.
>> >> @Dave
>> >> stays
>> much
>> >> better now).
>> >> thick
>> standing
>> towel
>> >> also
>> >> st
>> files:
> I have the plotter running - slow. And I always add angle to each 90ADVERTISEMENT
> deg trace
> trace. The
> and touchup
> plotter after
> doesn't seem
> > different inks.
> varies with
> > speed.
> corner.
> > st
> cut in
> > > the
> fitted
> > > into a
> fast. I
> > > heat Fe
> and
> > > apron. I
> seem to
> > > eat
> not a
> > > time to
> complete.
> > > You
> done.
> > >> @Dave
> resin.
> jar, it
> > >> stays
> too).
> is much
> > >> better now).
> leave a
> > >> thick
> standing
> towel
> and
> > >> also
> > >> st
> files:
> files:
> files:
> Yahoo! Groups Sponsor
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
On Fri, 26 Sep 2003 09:16:17 -0400, Don Perry <mojo@...> wrote:
> The pen from GC electronics Cat # 22-222 is black with 1/64 tip. Not
> sure just what the tip might be, but its not metal. They do dry out
> easy, so be sure to cap it when your done. But the price was only $2.XX
> something each at my local store. My plotter was $40 from the scrap
> yard and is a HP7475.
>> deg trace
>> trace. The
>> and touchup
>> plotter after
>> doesn't seem
>> > different inks.
>> varies with
>> > speed.
>> corner.
>> > st
>> cut in
>> > > the
>> fitted
>> > > into a
>> fast. I
>> > > heat Fe
>> and
>> > > apron. I
>> seem to
>> > > eat
>> not a
>> > > time to
>> complete.
>> > > You
>> done.
>> > >> @Dave
>> resin.
>> jar, it
>> > >> stays
>> too).
>> is much
>> > >> better now).
>> leave a
>> > >> thick
>> standing
>> towel
>> and
>> > >> also
>> > >> st
>> files:
>> files:
>> files:
> ADVERTISEMENT
> [click here]
> and it has nylon tip?
> or felt?
> or metal?
> thanks
> st
> > trace
> > The
> > touchup
> > after
> > seem
> >> different inks.
> >> with
> >> speed.
> >> st
> >> in
> >> > the
> >> fitted
> >> > into a
> >> > heat Fe
> >> > apron. I
> >> to
> >> > eat
> >> a
> >> > time to
> >> complete.
> >> > You
> >> done.
> >> >> @Dave
> >> >> stays
> >> much
> >> >> better now).
> >> >> thick
> >> standing
> >> towel
> >> >> also
> >> >> st
> >> files:
> i fear i can't get exactly that one, thus i am asking..
> (not even know what gc electronics is...)
> do they have online descriptions of products?
> st
> >> deg trace
> >> trace. The
> >> and touchup
> >> plotter after
> >> doesn't seem
> >> > different inks.
> >> varies with
> >> > speed.
> >> corner.
> >> > st
> >> cut in
> >> > > the
> >> fitted
> >> > > into a
> >> fast. I
> >> > > heat Fe
> >> and
> >> > > apron. I
> >> seem to
> >> > > eat
> >> not a
> >> > > time to
> >> complete.
> >> > > You
> >> done.
> >> > >> @Dave
> >> resin.
> >> jar, it
> >> > >> stays
> >> too).
> >> is much
> >> > >> better now).
> >> leave a
> >> > >> thick
> >> standing
> >> towel
> >> and
> >> > >> also
> >> > >> st
> >> files:
> >> files:
> >> files:
> > ADVERTISEMENT
> > [click here]
On Fri, 26 Sep 2003 09:30:51 -0400, Don Perry <mojo@...> wrote:
> I have a what looks like a brand new GC catalog right here in my hand.
> It says
> 1-800-435-2931 customer service. A division of GC thorsen Inc. 1801
> Morgan
> Street Rockford, IL I don't see a web site posted on it.
>> st
>> $2.XX
>> >> deg trace
>> >> trace. The
>> >> and touchup
>> >> plotter after
>> >> doesn't seem
>> >> > different inks.
>> >> varies with
>> >> > speed.
>> >> corner.
>> >> > st
>> >> cut in
>> >> > > the
>> >> fitted
>> >> > > into a
>> >> fast. I
>> >> > > heat Fe
>> >> and
>> >> > > apron. I
>> >> seem to
>> >> > > eat
>> >> not a
>> >> > > time to
>> >> complete.
>> >> > > You
>> >> done.
>> >> > >> @Dave
>> >> resin.
>> >> jar, it
>> >> > >> stays
>> >> too).
>> >> is much
>> >> > >> better now).
>> >> leave a
>> >> > >> thick
>> >> standing
>> paper
>> >> towel
>> layer
>> >> and
>> >> > >> also
>> >> > >> st
>> >> files:
>> >> files:
>> >> files:
>> > ADVERTISEMENT
>> > [click here]
>> files:
2003-09-27 by Dave Mucha
> It says
2003-09-27 by Stefan Trethan
> Google the phone number 800-435-2931
> www.gcwaldom.com
> Didn't find pens though.
> didn't Staedler have suppliers around the world ?
> seems an office supply place might offer some options.
> or, paint the whole board and with a small rotary cutter/scratcher,
> scratch off what you don't want, and leave the trace.
> Dave
> > It says
2003-09-27 by Ben H. Lanmon
> GC Electronics is under GC/Waldom website does not tell you much as I
> believe that you have to be registered dealer to get to most information
> on the site. They do give you access to there Dist. locator but think
> they are only U.S. and Canada that I saw.
> Mouser www.mouser.com I believe carries the GC Electronics resist pens
> but don't list them as GC Electronics. They list two pen widths
> 1/32" and 1/64" or .79 mm and .39 mm. these list for $2.48 and $2.64
> each Page 1040 in Cat.#615
> MG Chemicals has a resist pen www.mgchemicals.com I buy MG Chemicals
> thru Circuit Specialists www.web-tronics.com MG Chemicals pen is only
> listed for use with Ferric Chloride and Sodium Persulfate, not for use
> with Ammonium Persulfate.
> These pens look just like a Shapie, in fact I use a fine point Shapie to
> do touch up when needed on my boards, I use Ferric Chloride Etchant.
> Ben
