DIY conductive vias ?
2009-06-09 by a3v03v0
Has anyone tried used a conductive pen such as the ITW Chemtronics CW2200MTP for making vias conductive. Once the via has been treated with the pen it may be possible to solder it with a low temperature solder. Found this "Curing: Tack-free in 3 to 5 minutes at room temperature. Achieves electrical conductivity within 30 minutes. Heat cure for 5 minutes at 250 to 300°F (120 to 150°C) for maximum conductivity, durability and chemical resistance. Soldering: Low temperature soldering is possible to the heat-cured silver conductive traces if done at 350°F (177°C) for <5 seconds." Note: Solder iron tip temperatures are most commonly between 315-371°C (600-700°F) for Sn63Pb37 and Sn62Pb36Ag02 alloys. It looks like we have to use a low temp solder. SnIn20Ag2.8 may work but I have not found a source for it. [Non-text portions of this message have been removed]
