First PCB
First PCB
2007-01-10 by DB Express
I just etched my PS board this morning.  Not too bad for a first try:
http://members.lsol.net/gop4evr/unlinked/psboard.jpg
I used homebrew etchant (2:1 hydrogen peroxide/muriatic acid).  At $2.69/gallon for the muriatic acid and 69 cents/quart for hydrogen peroxide, this sure beats paying $6/pint for the FeCl.  It works well, but has some odor.  I used it outside just as an extra precaution.
Those who were following this project on E101 will notice that I rotated the regs 90 degrees (to make room for the heat sinks and give better airflow).  It was suggested that I add some filled areas for heat dissipation, and I probably went overboard.  I figured that since I had the room to work with, the wider traces couldn't hurt anything and would also give me some fudge room in case of etching voids.  I am pleased with the result, which was made possible by the information I gleaned from this group and related web sites.  Thanks guys.
Nels
Do You Yahoo!?
http://mail.yahoo.com
Re: [Homebrew_PCBs] First PCB
2007-01-10 by Lez
Can someone explain what this really is?
Such names are meaningless in any other country except the states?
Hydrogen peroxide I think is hair bleach, but if I buy that its
probably got other things in it to spoil it.
What is a muriatic ?
Citric acid is citrus which is orange and lemons, but whats a muriatic
tree look like....
Sorry for giving eveyone a laugh but like I have said before, this is
the UK, we only have maplins and the farm for milk and eggs....
Lez
2007-01-10 by Leon
Sent: Wednesday, January 10, 2007 4:56 PM
Subject: Re: [Homebrew_PCBs] First PCB
tree look like....
Hydrogen peroxide is H2O2, used as a bleach by hairdressers. High strength
H2O2 might be difficult to obtain, suicide bombers often use the stuff to
make their explosives.
Muriatic acid is the old-fashioned name for hydrochloric acid (HCl). 30% HC1
is available from hardware stores and building suppliers, it is often used
for cleaning drains and brickwork.
Leon
----- Original Message ----
(Reading from the bottles)
Muriatic acid:
Hydrogen Chloride -- 31.45% (hydrochloric acid)
Inert ingredients -- 68.55%
This mixture is sold as a farm and industrial solvent/cleaner.  It is used in swmming pools (scary, huh?), and for etching concrete, among many other uses.
Hydrogen peroxide:
"Hydrogen Peroxide Topical Soulution"
"Hydrogen Peroxide (stabilized) 3%"
This is sold here as a solution for cleaning minor cuts and other home medical uses.  I had to use it when I was younger to irrigate an infected ear (not a happy memory).
Do You Yahoo!?
2007-01-10 by Stefan Trethan
> tree look like....
> Lez
Muriatic acid is really called hydrochloric acid, HCl, muriatic acid is
indeed a US thing, and comes in a variety of (mis-)spellings. I do not
know what "muriatic" comes from either.
Hydrogen peroxide is the correct name for the second chemical though,
H2O2. Seems just like water, but has more oxygen, which is what we need
 from it. It is used in "peroxide" bleach. It was used in the "old days" to
disinfect, similar to iodine (stings too i'm told).
ST
2007-01-10 by DJ Delorie
Lez <lez.briddon@...> writes:
Hydrogen Peroxide is H2O2 : http://en.wikipedia.org/wiki/Hydrogen_peroxide
Muriatic acid is HCl in H2O : http://en.wikipedia.org/wiki/Muriatic_acid
Er, they're chemical names.  They should be meaningful in any country.
*Obtaining* them, however, seems to be country-specific, and you have
to get the right strengths (dilutions).
Not bad at all! I wish my first try would have had any traces on it ;-)
Now you should look into care and feeding of this etchant as CuCl. You can
use it forever only replenishing small amounts of HCl and regenerating
with H2O2. You will want to get H2O2 in high concentration (above 20%), or
you'll add too much water.
How to maintain CuCl can be found in the links section, although many
guides make it way too complicated.
If your etchant was fuming or bubbling you probably had a much too high
concentration of one or both of the chemicals. CuCl will not cause any
smell, or cause any rust to nearby parts, if the concentrations are within
reason and it is covered when not in use.
> Nels
Also, by using a larger copper area you saved etchant.
ST
2007-01-10 by James Washer
Was the H2O2 you used the common over-the-counter drugstore variety (~3%) or the more concentrated (and very dangerous) lab supply kind.
 - jim
On Wed, 10 Jan 2007 08:50:01 -0800 (PST)
> Nels
> Do You Yahoo!?
 - jim
3% solution, as sold in drug stores.
Nels
Do You Yahoo!?
Re: First PCB
2007-01-10 by mycroft2152
Hydrogen Peroxide is still used in food processing to disinfect
packages. For aseptic packaging, milk cartons are first sprayed with
H2O2 and then heated. The heat decomposes the H2O2 to water and O2
and the carton is then filled and sealed. This all happens in a
matter of seconds.
Myc
muriatic
> > tree look like....
this is
> > Lez
acid is
not
though,
need
days" to
> ST
Re: [Homebrew_PCBs] Re: First PCB
On Wed, 10 Jan 2007 20:47:02 +0100, mycroft2152 <mycroft2152y@...>
> matter of seconds.
> Myc
I think it's quite useful stuff, since it leaves nothing harmful.
I've seen it recommended for a whole lot of applications, not sure how
much of that is really working. I tried one time to use it as bleach in
the washing machine but could not detect any effect.
Seems like a good alternative for those people who have to disinfect
everything in the house all the time, with H2O2 they would at least do no
harm. But then there was that story about parents accidentally giving
their child concentrated H2O2 internally, leading to serious injury. Your
body was _not_ meant to process H2O2, so don't drink your PCB making
chemicals ;-).
ST
Re: [Homebrew_PCBs] "Muriatic Acid" Etymology
2007-01-10 by Roland Harriston
Hydrochloric acid was first discovered around the year 800 AD by the
alchemist <http://en.wikipedia.org/wiki/Alchemy_%28islam%29> Jabir ibn
Hayyan (Geber) <http://en.wikipedia.org/wiki/Geber>, by mixing common
salt <http://en.wikipedia.org/wiki/Sodium_chloride> with vitriol
<http://en.wikipedia.org/wiki/Vitriol> (sulfuric acid
<http://en.wikipedia.org/wiki/Sulfuric_acid>).
In the Middle Ages, hydrochloric acid was known to European alchemists
as spirit of salt or acidum salis. Gaseous HCl was called marine acid
air. The old (pre-systematic) name muriatic acid has the same origin
(muriatic means "pertaining to brine or salt"), and this name is still
sometimes used.
Roland F.  Harriston
Re: First PCB
2007-01-11 by Dave Mucha
If I may go off topic on the side of safety and household hazzards.
As you probably found out, the chemicals you used were rather good at
removing metal.
What you may soon find out, they are SO good, that EVERYTHING metal in
the room in which they are kept will start to rust.  stuff across the
basement and inside of wooden boxes.
I took my Muriatic Acid, sold as such to etch stone and clean
concrete, and I put that into a 5 gallon bucket with a lid that had an
O-ring of silly-cone.
Dave
2007-01-11 by Stefan Trethan
On Thu, 11 Jan 2007 02:27:14 +0100, Dave Mucha <dave_mucha@...>
> removing metal.
> Dave
Plastic bottles seem to be the problem. Although i can not agree about
"across the basement", something put next to a PE bottle of HCl will rust.
Also, the bottle will degrade and on the outside you can find some sort of
salt crystals after some time. I use glass bottles for HCl and H2O2 now.
(H2O2 will make PE bottles brittle from the inside). Glass seems more
resistant, but breakage is a danger.
You could also put the HCl inside a second larger container, say a bucket
with lid. Then it may work to put some chemical in the space between to
neutralize any acid, maybe NaOH or something. Not sure if the fumes can be
neutralized this way, but even the two containers should trap most of the
fumes if you open them outside or something.
You should _never ever_ store any chemicals on a shelf or on the floor or
something without a second container for safety in case the bottle fails.
Plastic bottles _will_ fail if given enough time, especially with the aid
of some chemicals. So put them in a bucket or plastic crate or something.
(Hint: butchers have great plastic crates that are very sturdy, with two
handles. I keep the etching tank in such a crate, and the chemical bottles
behind it in the same crate.)
ST
2007-01-11 by Lez
>  sometimes used
ok, I'l stick to buying FECL at least I can find that stuff.
It took me 2 years to find out what lye was.........
Lez
Have you heard about google? ;-)
ST
2007-01-11 by Roland Harriston
Lez:
If you happen to live in the southwest USA where there are lots
of backyard swimming pools, you can find muriatic acid in
the local supermarkets along with other pool  maintenance
supplies.  Most of the local Ace Hardware stores can get
muriatic acid for you if they don't already have it in stock.
Also, a lot of  construction and building supply emporiums
like Home Depot stock muriatic acid, although they
generally have it large plastic bottles, like one or five gallons.
Ace Hardware stocks it in 1 quart plastic bottles in my area.
And speaking of outgassing and corrosion: Consider the
approximately 1 liter of sulphuric acid that almost everyone
has sitting in the garage most of the time. I'm referring to
the acid in your car battery, and car battery acid is much
stronger (Baume) than domestic Muriatic acid.  And besides
some car batteries are vented!
To date, I have not noticed any of my tools, electronic
test equipment, photolab stuff being attacked by the
gaseous products from batteries in the two cars
residing in my garage, nor have I seen any ill-effects
on the automobiles, paint, wiring, trim,etc.
Personally, I detest Ferric Chloride....nasty stuff.
Roland F. Harriston
> <http://en.wikipedia.org/wiki/Alchemy_%28islam%29>> Jabir ibn
> <http://en.wikipedia.org/wiki/Geber>>, by mixing common
> <http://en.wikipedia.org/wiki/Sodium_chloride>> with vitriol
> <http://en.wikipedia.org/wiki/Vitriol>> (sulfuric acid
> <http://en.wikipedia.org/wiki/Sulfuric_acid>>).
> > sometimes used
> Lez
2007-01-11 by Lez
>  Roland F. Harriston
I hate the cost of it if I can use something cheaper etc, never tried
sulphuric acid.......
Lez
2007-01-11 by AnaLog Services, Inc.
Two completely different mineral acids you are talking about.  Hydrochloric
produces Chlorine gas, and I promise it will corrode things in the vacinity.
Sulpuric is not as bad about corroding things near it, although take a look
at the battery tray in an older vehicle for an example of what it can do.
Neither is particularly dangeraos compared to say Hydrofluric acid; it is
horrible and very dangerous (etches / dissolves glass, even).
Sent: Thursday, January 11, 2007 10:27 AM
Subject: Re: [Homebrew_PCBs] "Muriatic Acid" Etymology
Lez:
Roland F. Harriston
On Thu, 11 Jan 2007 16:27:23 +0100, Roland Harriston <rolohar@...>
You make the assumption here that the two acids would be similar.
Sulphuric acid does not evaporate and form fumes in the same way as
hydrochloric acid.
I don't pretend to understand all those complicated things like vapor
pressure, but maybe someone else is qualified to elaborate.
Look at the boiling points though, over 300C for sulphuric acid and
something like 50 or 60C for HCl. That'll tell you something about how
well is evaporating at room temperature.
I can confirm from first hand experience, not assumption, that HCl will
cause stuff to rust, if left open, in a significant area. Even a closed
plastic bottle made a spray can rust which was inches away.
ST
2007-01-11 by Lez
But can battery acid be used as an etchant?
Lez
I do not think so, but the experts in here will know.  They are talking about Hydrochloric acid mixed with hydrogen peroxide, not Sulfuric acid as far as I know.
Incidentally, drug store concentration peroxide is safe to handle, but the lab grade concentrated stuff is quite dangerous.  It has so much oxygen available, that a spec of dust falling in the bottle of highly concentrated hydrogen peroxide can cause a violent reaction.
Also, I think you will find "Muriatic" is an old world term, and should be commonly understood there in the UK as well as here in the New World.  Masons have used it since antiquity and it is used in many other trades.
  Sent: Thursday, January 11, 2007 12:15 PM
  Lez
> Lez
Sulphuric acid can be used in combination with H2O2 regeneration in a
copper sulphate producing process similar to CuCl. There was some good
reason why CuCl is better for homebrew use, but i can't remember it now.
ST
2007-01-11 by lists
In article <005101c735a7$5c6c7210$0100a8c0@House>,
"Historic" term is the word, everyone I know would refer to it as
"Hydrochloric"
Re: [Homebrew_PCBs] "Muriatic Acid": Corrosion, Etc.
Analog:
I have had muriatic acid in plastic containers in my garage
for a while now, and have not noticed that it has affected
anything in the garage, including the items previously
mentioned. In this neck of the woods, I don't think it is unusual for
folks to have muriatic acid and other pool maintenance
chemicals around the house most of the time, and nearly
all of this time the materials are in the containers they
were purchased in.
I don't know about having the peroxide/muriatic acid mixture
setting around the house, because I usually neutralize the batch
I have just used with sodium bicarbonate, and get rid of it.
The stuff is cheap enough to allow me to do this.
Since the southern Arizona desert is a very arid environment,
we don't have the relative humidity that might cause problems
in other portions of the world.
And, it is not unusual for the temperature to go up to 90 degrees F (or
higher)
in my garage during the summer months.
In the supermarkets around here, I see a large number of 4-pack
cartons of muriatic acid, each containing 4,  1gallon jugs.
I have never seen or heard of any ill-effects on anything else in the
supermarket
as a result of being around that much muriatic acid 24 hours, 7 days a week,
356 days a year.  At the local Home Depot, the 5 gallon jugs of muriatic
are stored outside in the garden supply area, but I think this is simply
because all the other pool maintenance stuff is out there.  At Ace
Hardware, 1 qt and 1 gal jugs are on the shelves inside the store.
This leads me to believe that it is the strength of the substance (Baume)
that makes the difference.
I'll close my contribution to this discussion by stating that my personal
experience has shown that the peroxide/muriatic acid etchant is
both effective and economical.  In addition, it leaves no ugly brown
stains.
The most important part is that my wife has informed that she will pay for
all the peroxide and muriatic acid I can possibly use.....if I just
don't bring
that "brown stuff" anywhere near the house anymore!
That means I can integrate some of my hobby expenses into the weekly
grocery bill.
Roland F. Harriston
> Hydrochloric
> vacinity.
> look
> From: Roland Harriston
> To: Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com>
> Lez:
> Roland F. Harriston
I would not expect you to have much trouble with it in sealed containers.  And certainly your low humidity is a factor (the gas goes back into solution in the water vapor in high humidity environments and is responsible for much of the corrosion seen).  Nevertheless, even out there where it is dry, if you leave open containers of the stuff laying around, you will see nasty effects.
  Sent: Thursday, January 11, 2007 2:37 PM
  Subject: Re: [Homebrew_PCBs] "Muriatic Acid": Corrosion, Etc.
  Analog:
  were purchased in.
  higher)
  supermarket
  stains.
  don't bring
  grocery bill.
  Roland F. Harriston
  > Hydrochloric
  > vacinity.
  > look
  > Lez:
  > Roland F. Harriston
Analog:
I fully agree that having open containers of almost _anything
_is a bad idea!
That's why I always finish off a bottle of vodka
as quickly as possible, once the seal has been broken!
Roland F. Harriston
> ,___
It is indeed an historic name, but it is still in common use.
  Sent: Thursday, January 11, 2007 2:12 PM
  "Hydrochloric"
2007-01-11 by lists
In article <xnsleizsdf.fsf@...>,
Muriatic is NOT a standard chemical name. Someone from the 19th century
would be familiar with it but not anymore. I have a very old chemistry
text book from around 1870 in which such names are common place but it
would be found in no chemical text book printed after WWII
Re: First PCB
2007-01-12 by Dave Mucha
--- In Homebrew_PCBs@yahoogroups.com, lists <stuart.winsor.lists@...>
It may be an old term, but you can find it in almost any hardware
store with the label of Muriatic acid.
Lowes has it on their web site, and every contractor I have ever
spoken to about etching or cleaning concrete offers Muriatic Acid
before anything else.
It's roots are old, but it's name is well known.
But, I suspect it is staying around because of the old timers.  the
kids will probably know it by both and at some point, it will be
somethin us old farts reminiss about.
Dave
2007-01-12 by Herbert E. Plett
If I walk into a store and ask for "Hydrocloric" acid, all what I will get is a
dumb look. If I ask for "Muriatic" then even the cashier will point to the
right shelf!
Ever heard about "lye" or "baking soda"? Are they chemical names?
Do you Yahoo!?
Everyone is raving about the all-new Yahoo! Mail beta.
http://new.mail.yahoo.com
2007-01-12 by AnaLog Services, Inc.
Just for fun, I checked Google, and got 257,000 hits for Muriatic acid, so somebody is still familiar with the term!  It was certainly mentioned in my high school chemistry text as a common name for Hydrochloric acid, but that was admittedly a few years back.  There is nothing wrong with the common or generic names for chemicals.  You are simply wrong that Muriatic acid is an obsolete or improper term.  For purposes of clarity, Hydrochloric acid is the better technical term, but demanding the use of the proper technical term would be like demanding folks stop calling ASA aspirin, since aspirin is a very old common name and not the correct technical chemical name.
  Sent: Thursday, January 11, 2007 5:45 PM
2007-01-12 by Leon
Sent: Friday, January 12, 2007 4:52 AM
"Spirits of salts" is what it is often called here in the UK. That is a very
old name.
Leon
Leon Heller
Amateur radio call-sign G1HSM
Yaesu FT-817ND transceiver
Suzuki SV1000S motorcycle
leon355@...
2007-01-12 by Stefan Trethan
On Thu, 11 Jan 2007 23:45:02 +0100, lists
Give it up, it's a US thing. They like them old obsolete terms, same with
yards, inches, feet and the like.
You'll never talk sense into them, it's a matter of pride.
ST
2007-01-12 by Lez
> ST
Well as being British we invented the roots of there language, now
there trying to teach it us with their colorful ways.........
But I think your right about the terms, they wont change, like the
American mindset, no retreat, no surrender.............
As for using google to prove the popularity of a word, as its hitting
about 80% of american sites and 20% of them are from the rest of the
world, no wonder the American spellings have higher hits.
2007-01-12 by Lez
Yes maybe, but it wont be on sale as that in the uk, even under a
different name, we DONT sell chemicals over the counter in the UK,
they have to ordered, with all the paperwork, from checmical supply
companies.
So, the only way in the UK to get something is to hope that it has a
legitimate use for sale, IE lye for cleaning drains, although very
rare is lye sold in the uk, or that it is used in sufficient
concentration in another kitchen product etc that it can be used as is
or refined.
This is all to do with bombs etc and general public safety, if its
harmful, we dont sell it, I cant imagine the amount of problems the
last bombers had to get anything..........
Lez
RE: [Homebrew_PCBs] First PCB
2007-01-12 by Tony Smith
> terms, same
> > with yards, inches, feet and the like.
> > ST
> language, now there trying to teach it us with their colorful
> ways.........
> like the American mindset, no retreat, no surrender.............
> hitting about 80% of american sites and 20% of them are from
> the rest of the world, no wonder the American spellings have
> higher hits.
NASA has gone metric, hooray say those who probes are splattered over Mars.
Well, some of them.
I did have a chuckle at an American 'lifestyle' program the other day.  A
bunch of builders/contractors were trying to make some wooden arches, which
involved a bit of maths.  Much muttering & grumbling about fractions was
heard, the end result being they got it wrong anyway.  I guess they couldn't
afford the fancy nerd calculators.  Or just go metric and do all your
measuring in millimeters, it's easier than you think.
Pay closer attention to Google, it kind of treats different spellings as the
same, but the results are not quite that you think.  Compare color & colour.
Tony
Probably very little.
"problems" is a relative term, and become rather small if you are planning
to blow yourself up ;-)
<http://news.bbc.co.uk/1/hi/programmes/kenyon_confronts/3149502.stm>
H2O2 is sold as pool chemical (for oxygen based systems), usually as 25%
under different brand names. HCl should be available as pool chemical too,
although here it is only used for public pools, private ones use a dry
substance instead.
I would still suggest trying to jump through all the hoops in order to buy
chemicals for your legitimate use, just to spite them if nothing else.
Also, if you want to buy chamicals, you need to find specialist chemicals
shops, not pharmacies, or DIY stores, or anything.
ST
Offensive nonsense.
  Sent: Friday, January 12, 2007 8:02 AM
  > ST
2007-01-12 by Lez
> substance instead.
In the city of york I know 0 ppl with pools, in the village I grew up
in, 0, in my brother in laws town, 0....................
Our BEST kitchen / household chemical suppliers are...........
http://www.maplin.co.uk/
http://www.asda.co.uk/
http://www.boots.co.uk/
they sell things like kitchen worktop cleaner, products based on 'citrus power'
Doing a search I have found it de-scales ? is this right ? if so maybe
its used in de-scaling products designed to be dropped into the toilet
bowl and left overnight...........
box says 5%(oxygen based bleaching agent, anionic surfactants,
polycarboxylates), 95%other ingrediants
I have however found this..........
https://www.helios.co.uk/cgi-bin/store.cgi?action=link&sku=Muri-ac&uid=1762
QED.
> -----Original Message-----
> From: Homebrew_PCBs@yahoogroups.com
> [mailto:Homebrew_PCBs@yahoogroups.com] On Behalf Of AnaLog
> Services, Inc.
> Sent: Saturday, 13 January 2007 2:31 AM
> Offensive nonsense.
>   From: Lez
> terms, same with
>   > ST
> its hitting
> Files, and Photos:
> power'
How about <http://www.scichem.com/>?
De-scalers could contain HCl (that would work well), but could also be
beased on something else that will not corrode metals.
ST
2007-01-12 by Terry Owens
Well as being British we invented the roots of there (their) language, now
there (they are) trying to teach it us with their colorful (colourful) ways.........
But (grammar; starting a sentence with 'But') I think your right about the terms, they wont (won't, as in will not?) change, like the American mindset, no retreat, no surrender.............
Being British myself, I find it offensive when someone from my country criticises the colonials in their use of English, when they patently cannot use it themselves. See corrections above.
What has this to do with printed circuit board making?
Terry
Offensive nonsense.
  > ST
Yahoo! Groups Links
Re: First PCB
2007-01-12 by Phil Mattison
Remarkable. It seems even among the British there are many who don't know
the difference between there, their and they're. Not to mention the correct
use of apostrophe, capitalization and punctuation. Not that Americans are
any better. Probably a result of public school emphasis on diversity at the
expense of education.
Phil Mattison
http://www.ohmikron.com/
Motors::Drivers::Controllers::Software
Re: First PCB - safety
bucket
> with lid.
This is what I did.  I used the origional plastic bottle. figuring the
supplier/packager put the Muriatic acid in a suitable container.
I then placed that container inside of a 5 gallon bucket with a lid.
the bucket is an old paint bucket.
What I did not do, and should, is to full the lower space with kitty
letter to absorb any spills.
I did notice the white crystals that, I assume were from fumes
adsorbing near the cap.  I also noticed that things within about 3
meters had rust on them, and raw pc boards that were about 6 meters
away had started to oxidize.
Once I incapsulated the origional plastic bottle, there have not been
any further rusting or oxidation episodes.
Secondary containent is a good idea, and a method of absorbing any
spills is an excelent one.
Dave
ps: Phil, life is two short to worry about how words are used on
they're side of the pond.  I to do have to think about how there words
are used when I translate from over their to over here.  your better
off being more forgiving on posts as some day, you're posts will be
pulled apart as someone will think they have too point your you're errors.
http://www.better-english.com/easier/theyre.htm
And, yes, there is not one 'to' or 'there' in that paragraph is that
is in the correct place.  If you're too senstive, their posts will
driver you from here to there and back.
Dave
Re: [Homebrew_PCBs] Re: First PCB - safety
On Fri, 12 Jan 2007 20:11:43 +0100, Dave Mucha <dave_mucha@...>
I'm not so sure now that's actually a good idea. In case of a spill a
violent chemical reaction would take place, probably releasing gasses that
might put the bucket under pressure or heat causing all sorts of trouble.
Also, "pure" HCl seems easier to re-use or neutralize for disposal than
some mixtures you might get.
ST
2007-01-12 by lists
In article <c3241b80701120758u5bc2632ob28aa41e44c5dcc0@...>,
Hmmmm, seems a bit strange. However, a little while ago I came across:
http://www.labpakchemicals.com/
I was deterred by the £50 minimum order but maybe us UK members could get
together to make up a £50 order and then split it between us.
Note that 1 litre 36% HCl is £5.99 and 2litre 100Vol H2O2 is £8.29
Stuart
2007-01-12 by Wayne Topa
Thanks for that Terry.  We let is slide, as we knew he was english.
WT
2007-01-13 by Herbert E. Plett
BTW, do you know what the standard (definition) for an inch is?
believe it or not: it's 0.0254 meter! so, at last, the US 'IS' metric, although
a very crazy one... go figure!
Want to start your own business?
Learn how on Yahoo! Small Business.
http://smallbusiness.yahoo.com/r-index
I guess the bombers had little or no problem getting what they needed, these
laws are targeted towards the general public not for specifics, it's a matter
of 'public relations'.
We had similar ambient during our 'socialist' epoch.
If you really need to prohibit all danger, cut off the water supply... just too
many people have drowned!
Now that's room service!  Choose from over 150,000 hotels
in 45,000 destinations on Yahoo! Travel to find your fit.
http://farechase.yahoo.com/promo-generic-14795097
2007-01-13 by Lez
Well what do you expect after over 10 years of having to converse in
Anglish.......
I make no point of saying I'm the keeper of the ring of pure grammer,
having little education in things like 'history' and 'english' and any
other subject that was not scientific, I opted out of those to do
physics, woodwork and metal work, then left school early to work in
an, ooh what do you call them, 'autoshop' ? -  a place were people
bring their cars to be repaired?
I dont want to have offended anybody what I wrote was tongue in cheek,
if that translates I dont know. over their you may do something
different, finger in ear or something.
Lez
2007-01-13 by Leon
Sent: Friday, January 12, 2007 9:01 PM
I was deterred by the \ufffd50 minimum order but maybe us UK members could get
together to make up a \ufffd50 order and then split it between us.
Note that 1 litre 36% HCl is \ufffd5.99 and 2litre 100Vol H2O2 is \ufffd8.29
I'd be interested.
Leon
Leon Heller
leon355@...
2007-01-13 by Stefan Trethan
On Fri, 12 Jan 2007 22:01:02 +0100, lists
> Stuart
Even so, seems quite expensive. If you really only need H2O2 and HCl i
suspect the pool chemicals route may be the way to go after all. I suggest
going to your local _public_ pool and asking them for their supplier. HCl
should be found that way.
If the pool chemicals supplier does not have H2O2 as well, try a
hairdressers supply. Although they usually use gel H2O2 these days, i have
seen liquid one for sale there and also above 20% concentration.
ST
2007-01-13 by Derryck Croker
Used in the right circumstances it is OK.
It gets harder and harder to spell and punctuate when there are so
many mistakes made - even leaving aside the country differences.
Quite a lot really. Can change the meaning of a sentence.
Cheers
Derryck
On Sat, 13 Jan 2007 11:20:14 +0100, Leon <leon355@...> wrote:
> I'd be interested.
> Leon
Is it tricky in the UK to send chemicals via mail? I mean one could argue
they didn't have to know, but still, i think not all postal services allow
strong acids and stuff.
I'd still suggest spending some time on the phone, or visiting relevant
places. Even if they can't help you they'll send you somewhere else where
they may have what you want. For example if you call a bulk distributor
they'll usually be able to tell you where you can buy small quantities,
because those shops are their customers, and you can be sure they got
requests just like yours many times before.
ST
2007-01-13 by Lez
Yup if the minimum is 50 quid, add the dreaded vat and the delivery,
then if thats split between a group of us etc then I'm in, I suppose
it would need a minimum of 6 of us to make this work, as it looks like
the required stuff will be about a tenner.
Hope discussing this we are not infringing any group buy policy this
group as, I know some forums I use dont allow you to discuss group
buys etc.
Can I suggest a list fo interested ppl?
if so I'll start the list........
L. Briddon.
Re: "Muriatic Acid" Etymology
2007-01-13 by Dave Mucha
> buys etc.
> L. Briddon.
I know there was some discusssion about the proper term, Muriatic acid
or HCL.  I checked here in the States, and I can buy a gallon of
Muriatic Acid at the hardware store for less than $3.00 USD.
I checked a chemical company and it seems the cost of a gallon of HCL
37% electronics cleaning grade, is $105.00  USD
Dave
Re: [Homebrew_PCBs] Re: "Muriatic Acid" Etymology
2007-01-13 by AnaLog Services, Inc.
At that price, it would be some kind of laboratory grade (reagent grade or something).  We used to buy it in bulk for oilfield use at way less than a dollar a gallon.
  Sent: Saturday, January 13, 2007 7:31 AM
  Subject: [Homebrew_PCBs] Re: "Muriatic Acid" Etymology
  > buys etc.
  > L. Briddon.
  Dave
Not starting a sentence with "but", not ending a sentence with a preposition, not splitting an infinitive, and many others are artificial rules in English.  The got their start in Victorian times when the emerging middle class wanted to distinguish itself from the working class.  It is generally safe to ignore these particular rules if the sentence sounds better violating the rule.
  Sent: Saturday, January 13, 2007 5:53 AM
  Cheers
  Derryck
2007-01-13 by Tony Smith
> Services, Inc.
> Sent: Sunday, 14 January 2007 1:41 AM
Too right!  Down with all this modern crap!  If it was good enough for
great-great-great-great-grandpappy, it's good enough for the rest of ya.
Bring back vacuum tubes, F-cells and accumulators.  Silicon chips, bah
humbug.  And I'll have you know my car gets forty rods to the hogshead, and
that's the way I like it.
Someone should go & measure up Queen Lizzie, so we know how long a yard is
supposed to be.
Tony
2007-01-13 by YD
See http://www.dhmo.org/
- YD.
Cheap talk?
Check out Yahoo! Messenger's low PC-to-Phone call rates.
http://voice.yahoo.com
> > the water supply... just too many people have drowned!
oh, yes!  in our country not only milk gets contaminated with DHMO, but the
wine industry is also an abuser of DHMO.
And on-topic:
Addition of DHMO will make etching slower and less efficient.
Food fight? Enjoy some healthy debate
in the Yahoo! Answers Food & Drink Q&A.
http://answers.yahoo.com/dir/?link=list&sid=396545367
2007-01-13 by lists
In article <op.tl3ag6gsmg0lsf@tu-x2pj5qeyp2u4>,
> > I'd be interested.
> > Leon
Yes, though I think some couriers will transport stuff. Even so there is a
fair bit of legal stuff to handle, which would need to be gone into, and
regulations about labelling - never mind safe packing.
When I have bought Ferric Chloride crystals in the past, they arrived
sealed inside a heavy polythene bag inside a plastic tub inside a
cardboard box. This box was further packed inside another cardboard box
with lots of soft packing material around it. The outer box had lots of
stickers on the outside detailing the hazards.
> places.
Actually, the address of this place puts it about 20 miles from me so
'phoning and even collecting is easily possible. I just never got around
to it. I book-marked the link and then forgot about it. If life wasn't so
hectic at the moment I could think about it again.
If I did collect I've get to work out how to get it to the rest of you
guys. Depending where you live I think delivery/collection/meeting "half
way" might be the best way.
Stuart.
2007-01-15 by William Carr
> You can
> 20%), or
> high
> within
Last year I learned about Electrolytic Rust Removal.
To sum it up, you can add baking soda to water, drop a rusty piece of
metal in it attached to one lead from a battery charger, and put in a
piece of scrap metal attached to the other lead from that battery
charger.
By forcing electrons into the 'salt' solution you have created, the
rust on the metal you wish to reclaim is neutralized and falls off.
This process also destroys the scrap metal, causing it to rust away
within a few days until there's nothing of it left.
The piece of metal you wanted cleaned, however, comes out of the
'salt' bath with the rust turned black and falling off.
I bring this up because I wondered if the process could be used to
recharge etchant.   If you put a copper rod in as the sacrificial
scrap metal, you'd force copper into the solution.
William Carr
2007-01-15 by Stefan Trethan
On Mon, 15 Jan 2007 23:54:43 +0100, William Carr <Jkirk3279@...>
> William Carr
Actually, you use a graphite rod as one electrode, or both, since you want
to get copper out of it not into it. I've tried it, but it doesn't work
very well. Chlorine gas is produced at the electrode (of course! you plate
the Cu away from CuCl). This chlorine gas would need dissolving in the
etchant, otherwise you just pollute the air.
One suggestion to do this was a rotating electrode. i am not impressed by
that idea. I think one should try to make a downstream gas dissolver like
used by aquarium people to dissolve CO2. Basically a vertical tube filled
with obstructions like marbles, gas introduced at the bottom, and a pump
circulating water (in our case etchant) from the top to the bottom, so
there is a downflow. This slows down the gas dramatically, giving time for
dissolution (it could be closed up on top so any chlorine reaching the top
would accumulate for later dissolving instead of escaping).
Who knows it may even be suffucient to catch the chlorine gas in an
upside-down container and keep it there presented to the etchant for slow
dissolving without any pumps. I never tried.
A simple addition may be a magnetic stirrer to stir up the static
gas/water for faster reaction.
The way this copper recovery is done industrially is by using a membrane
between the electrodes that allows only ions through or something like
that, i don't fully understand the process. But it works for them.
It seems lotsa effort for little gain to me. With the small number of
boards i do excess CuCl has never been a problem.
ST
Re: First PCB
2007-01-16 by D
> > William Carr
you want
I've tried something similar to regenerate Ferric Chloride, using
an Iron electrode.  I did get Copper deposited out in the form of
Copper crystals.  And, some of the Iron was dissolved into the
solution.  However, I'm not sure if it formed Ferric Chloride or
Ferrous Chloride (or something else entirely).  I dont' remember
evolving any Chlorine gas, although I kept the current density
pretty low.
> I've tried it, but it doesn't work very well.
I don't remember if I ever tried the "regenerated" solution
(Like so many of my projects, I became distracted, and started
working on something else.).
Or reacted with the electrode material to form some nonvolatile
compound.
> This chlorine gas would need dissolving in the etchant, otherwise
And poison yourself and others.  Chlorine gas is NOT something to
play around with.  It will kill you in a most unplesant way.
> impressed by that idea. I think one should try to make a downstream
> gas dissolver like used by aquarium people to dissolve CO2.
It might be a good idea to check the solubility of Chlorine in
water first.  And, even if it dissolves, I'm not sure that's any
improvement, since it could later (when you least expect it) come
out of solution.  In my opinion, it'd be better to react it to
a nonvolatile form.
> Basically a vertical tube filled with obstructions like marbles,
> gas introduced at the bottom, and a pump circulating water (in our
> case etchant) from the top to the bottom, so there is a downflow.
> This slows down the gas dramatically, giving time for dissolution
Perhaps.  But, I'd want to work out all of the chemical equations
before even setting up a prototype operation.
> for slow dissolving without any pumps. I never tried.
Perhaps.  But, from what little I've done with Chlorine gas, and
from what I know about it, I'd just as soon stay as far away from it
as I can.  That sounds too much like an accident trying to happen.
Magnetic stirrers might help.  Also, maintaining the correct pH
of the solution may help.  Even irridation of the Cl2 might help
it to ionize and react with something (what?).
> membrane between the electrodes that allows only ions through or
> something like that, i don't fully understand the process. But it
> works for them.
Such membranes usually aren't cheap, nor are they usually
inexpensive.  But, they're probably the safer way to do things.
Probably.  The only reason I was looking into this was that Ferric
Chloride is a bit of a pain to obtain locally (inexpensively),
so regenerating the spent solution sounded like an interesting
option.  However, the Copper Chloride etchant sounds like an even
better idea (Note that you don't have to use the Hydrogen Peroxide
(H2O2) if you can areate the solution.).
> With the small number of  boards i do excess CuCl has never been a
> problem.
And, even if it was, there are probably better ways of handling
that.
> ST
Dave
2007-01-16 by Robert LaBudde
> > William Carr
><snip>
Some comments:
1. Chlorine gas is very corrosive to metals, including stainless steel. It
is very soluble in water and very toxic.
2. If your getting chlorine released, you have the wrong electrodes, the
wrong cell setup or too high a voltage differential.
3. Normally you make two half cells and connect them by a salt bridge. The
salt bridge consists typically of a U-shaped tube of glass or plastic
filled with a saturated KCl agar solution (solid, but conducts electricity).
4. If you want to eliminate the salt bridge, you need to make sure the
right reaction occurs in the two electrodes plus liquid.
5. If one electrode is copper and the other iron, the first reaction would
have to be Fe -> Fe++. You may end up with a solution that has FeCl2
instead of FeCl3.
6. You should gradually increase the voltage until current starts flowing.
If you push too high a voltage, strange reactions will start happening in
solution.
7. The rate of reaction is determined by the area of the electrodes, the
conductivity of the solution and temperature.
8. FeCl2 can be converted to FeCl3 via an oxidizing agent, such as H2O2,
although this also dilutes the solution from the H2O formed.
9. The solution containing FeCl2 can also be converted to FeCl3
electrolytically, using a salt bridge and another half-cell with a
sacrificial electrode.
10. If you choose the sacrificial electrode properly, just closing the
circuit can start the process without external power (you make an
electromotive cell). E.g., the other half cell could contain iodine or
permanganate or dichromate plus a carbon electrode.
11. Probably the simplest cell would be a graphite electrode in the etchant
with a salt bridge to a CuSO4 solution and a copper electrode, and drive
with sufficient voltage to force the reverse reaction.
All of these techniques involve extra chemicals and cost. One wonders
whether or not new etchant is not cheaper.
Robert A. LaBudde                      Email: ral@...
824 Timberlake Drive                   Tel: (757) 467-0954
Virginia Beach, VA 23464-3239          Fax: (757) 467-2947
2007-01-16 by Stefan Trethan
> a nonvolatile form.
It's not actually just dissolved in water, it is reacted with a Cu2Cl2 to
make two CuCl2 or something like that (i don't know nothing about
chemistry).
The chlorine is produced too fast at the electrode or something, so it
forms bubbles. If instead all the chlorine could be used to regenerate the
etchant this may work well.
I know chlorine is nothing to fool around with, but i believe the tiny
quantities created would be fairly safe to work with.
Industrial CuCl sometimes uses chlorine gas to regenerate, so there are
ways to make this work. If one were to look at the industrial processes,
how they get the chlorine to dissolve, the same might be done in small
scale with the chlorine produced at the electrode making electrolytic
regeneration a possibility.
As i said, if i would etch more i would look into it more closely, but
chemical regeneration is so cheap it would be foolish to waste time with
electroplating.
ST
