[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of mowens
Sent: Saturday, November 11, 2006 4:53 PM
Subject: Re: [Digital BW] 1280, UT2, EEM can't print cool
Paul,
It appears you are as dedicated to the board as I hope to be some day!
Thanks for the tip. I've started with both BW and color files in all
sorts of profiles (sRGB IEC...mostly). I converted both to adobe rgb
98 with gamma 2.2 before applying curve, then printing. No color
corrections in printing, so no gamma to pick in printing.
When I start with other files, they are usually in rgb and I have to
convert to BW. I've done this mainly by image>adjustments>color
mixer>monochrome + % R, G or B. Is this correct? I don't add any
Hue/saturation at this point.
My BO printing was very neutral, and easily cool. I added the other 5
cartridge UT2 inks and can't get rid of sepia...that's why I thought
it was just a matter of purging ink from the system. But after some
head cleans and 30 pics?
MO
--- In DigitalBlackandWhit
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com>
eThePrint@yahoogroups.com, "Paul Roark"
<paul.roark@...> wrote:
> Mike,
> Use the test strips at http://home1.
<http://home1.gte.net/res09aij/Test-files.htm>
to check
> the inkset.
> Be sure you're starting with a grayscale file in Gray Gamma 2.2
workspace.
> Sometimes there are embedded profiles that can mess things up. When
you're
> ready to print, then convert to RGB, apply the curve, check the driver
> settings, etc.
> Paul
> www.PaulRoark.com <http://www.paulroar <http://www.paulroark.com/> k.com/>
> _____
> From: DigitalBlackandWhit
mowens
> Sent: Saturday, November 11, 2006 10:00 AM
> Subject: [Digital BW] 1280, UT2, EEM can't print cool
> applied Paul Roark's UT2-EEM different curves to adobe RGB 98
> workspace print with predominate sepia (or brown) tone. Coolest I can
> get is light, light cream on a white backdrop image. Can't attain
> any silver or even blue tones. I tried not using curves, but changing
> color sliders for CMY too, same result.
> Black is eboni, standard T009 UT2 inkset, cleaned heads, printed about
> 20 images so far. After applying curves, printing with all color
> settings off, same adobe 98 rgb workspace. Tried different paper
> settings (matte heavyweight, and others), even printed on Canon Photo
> Paper Pro just to see...same tone.
> Seems it is the inkset, not the paper or settings?
> Thanks in advance...
> Mike
