Digital BW, The Print
Is my Epson 1280 fit for CIS?
2005-03-04 by toniko74
Hello,
A month ago I bought a used Epson 1280 in good shape. Now I want to
install CIS UT-2 to it. Please help me diagnose if the printer is fit
for it. What should I check? I did head allignment, all nozzles work,
on high glossy paper I get good banding-free prints. The only problem
I noticed is that with Epson Archival Matte (European Enhanced)I'm
getting visible banding. What settings in Epson's driver should I use
for this paper?
The amount of information in this group is enormous, I'm lost in all
the things I should check and learn before making b&w prints. I hope
somebody will be so nice to anser these apparently repeatedly asked
questions. My previous question about what accessories and spare part
to order from Inksupply together with UT-2 system was barely noticed.
I hope the day when I see my b&w prints made on the Epson finally
comes!
Regards
Tomek
RE: [Digital BW] Is my Epson 1280 fit for CIS?
2005-03-04 by Paul Roark
Tomek,
The UT2 inkset doesn't require any special printer performance.  However, if
your printer bands with OEM inks, it may well also band with UT2.
I generally print at 1440 dpi.  You might see if leaving High Speed
un-checked makes for better prints.  I find 2880 so slow, I'd hate to have
to use that for everything.
You might consider buying just a test cartridge of UT2 before investing in a
CFS.  Frankly, with the sponge-less, easy-refill carts likely to be released
this month, I would go that route instead of the more expensive and less
flexible continuous flow system.
Good luck.
Paul
www.PaulRoark.com
_____________________
Sent: Friday, March 04, 2005 1:32 AM
Subject: [Digital BW] Is my Epson 1280 fit for CIS?
Hello,
for this paper?
comes!
Regards
Tomek
Please visit the Group Homepage to check the Files, and other resources as
they are often being updated.
If you wish to receive no emails or just a daily digest, or you wish to
unsubscribe, please edit your Membership preferences by visiting this same
page.
Please follow these basic guidelines:
- As threads develop, trim off excess portions of earlier messages to keep
them short.
- Good manners are required at all time. No personal attacks or flames.
Hostile, aggressive or argumentative users may be removed from the
membership without notice.
- Keep your posts and threads related to the group topic of digital B&W
printing. Users who persistently make off-topic posts may be removed from
the membership.
- By posting on this forum you agree to abide by the group rules and
guidelines, and to abide by the actions and decisions of the group Owner and
Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND
"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY
TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR
ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY
THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups Links
Re: [Digital BW] Is my Epson 1280 fit for CIS?
2005-03-04 by jnhugo
Tomek:
I printed trouble free for over a year with a CFS on the 1280-
A few months ago I switched to the MIS CFS and UT2's and have had
nothing but headaches with it-
I would recommend you forget about a CFS and wait for the easier refillable
carts- that's what I plan to do.
I am convinced the new CFS killed my 1280-it needs 250.00 in repairs now.
I like the UT2's but hate the CFS-
Jack
2005-03-05 by Thomas Keesling
Tomek,
I've used the original CIS (not the MIS CFS) with my 1280 for about four
years. I've had only two problems in that time. The first problem was in the
beginning when I was trying to use InkjetMall's original pigment color inks
with the system. Clogging was a major problem and I ultimately returned the
inks for a refund. I then switched the printer/CIS to the MIS VM inkset. I
never had any problems with that set and then switched to the UT2 inks after
they became available. The UT2 inks were trouble-free as well until a couple
of weeks ago when the black cartridge began to cause problems. I replaced
the cartridge without any problems, but now the printer is apparently dying
and I'm considering buying a new 1280 and continuing to use this old CIS and
the UT2 inks (in part because of the $100 rebate on the printer and the fact
that I have a year's supply of UT2 ink that I just bought).
For all practical purposes, this printer/CIS/UT2 ink combination been
trouble-free for me and I'd highly recommend either this setup or the use of
the new refillable cartridges that are apparently on their way from MIS.
Good luck!
Tom Keesling
Intelligent Design
