--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Donald
Schiemann" <DSCHIEMANN@p...> wrote:
> I am confused about how to use the Curves/Blend feature in QuadTone
> RIP, with the separating percent box controlled by a slider. If one
> is printing on EEnhMatte, what would be the appropriate selections in
> each box? and how much blending? Appreciate any guidance.
> Donald
Really any combination you'd like. If cool is too cool for your taste
warm it up a bit with neutral, sepia or carbon. The slider can adjust
the percentage of mix. For instance I use cool-1 and neutral-2 at 65%
cool-1 a lot. I just like the look but I'm sure your taste is
different. You'll have to experiment as the choices are endless.
Tom
