I use and recommend Philips TL90 F17T8/TL950 florescent bulbs. They
are 24 inch long and fit nicely into any inexpensive florescent
fixture you can buy at Home Depot for $15 or so. They are rated
5000K and are designed for graphics viewing. Great for home office
use. They are also available in longer sizes if you want to light
your entire office.
I measured them with my Eye One and mine have a color temperature of
4854K, with a CRI (Color Rendering Index) of 96. Anything above 90
is excellent. CRI looks at the spectral energy in small segments and
compares them to the D50 standard. They are relatively inexpensive
and do a great job.
I have lost the information on where I bought them online, but I
think it was www.getbulbs.com. When I checked their site, it was
either temporarily offline or defunct. An internet search ought to
locate them.
Another source for good viewing lights is www.Solux.com, but their
lights are more expensive. They sell bayonet mount bulbs that are
very highly rated for critical color work.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Seth"
<seth@m...> wrote:
> Yep, I still prefer daylight (IF it's shining around here). Common
daylight
> flourescents are iffy, but probably more in line with what people
have.
> I have CR91 Daylight tubes in the darkroom, but didn't suggest
those since
> they ared pricey.
> A great combo I found was a four-bulb fixture alternating warm
flourescent
> and CR91's. The "warm bulbs actually look orangey like tungsten.
> It gives a good mix to simulate home/office. THE best is if I know
where
> they will view it so I can use some sliders and make adjustments.
> I have, on rare occasion, made some color prints with slightly
different
> tones, then asked the person what kind of light they would be
putting the
> print in, but that gets pricey also.
> Seth
> ==-----Original Message-----
> ==From: Djon [mailto:westsidemaurice@y...]
> ==I use an Ott light to partially simulate daylight, but mine's
> ==clearly a very partial, chopped spectrum. Shoot some color
> ==swatches with Ektachrome to see what I mean. Mine's
> ==significantly inferior to the common "daylight" fluorescent
> ==tubes that I use in lightboxes.
> ==Ott plus tungsten seems to me to be a good mix for print
> ==evaluation...it's not daylight, but most display situations
> ==aren't either. I find this mix works well for matching matte
> ==prints to my monitor.
> ==> I check white in pure sunlight or an Ott light. Flourescent has
that
> ==green
> ==> cavity and incandescent will warm the appearance of the paper.
> ==> Not a great test, but take it to a paint department that
> ==has different
> ==> lights for looking at their paint chips.
> ==> Seth
