emptying 1430
2015-07-07 by jacques.caron@...
Hi I'm using an Epson 1430 with EB6 standard inks; my problem : I fill all the cartridges but… two days later, without printing, the black and "yellow" cartridge are empty???
Should I change the cartridge for new ones or is there something else that I'M missing?
Many thanks
2015-07-07 by David Kachel
Shut down and restart. If that fails, run a cleaning cycle. The 1430 is just strange that way. Mine does the same thing, David Kachel ___________________ Artist-Photographer Fine B&W Photographs WEBSITE: www.davidkachel.com BLOG: thetransparentphotographer.com EMAIL: david@... PO Box 173 Globe, AZ 85502 (928) 275-0925
From: "jacques.caron@... [DigitalBlackandWhiteThePrint]" <DigitalBlackandWhiteThePrint@yahoogroups.com> Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Date: Tuesday, July 7, 2015 at 12:29 PM To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Subject: [Digital BW] emptying 1430 Should I change the cartridge for new ones or is there something else that I'M missing?
2015-07-07 by Jacques Caron
Shut down and restart. If that fails, run a cleaning cycle. The 1430 is just strange that way. Mine does the same thing,David Kachel.
2015-07-07 by Paul Roark
Many thanks
Thanks Paul! Found it very odd too! Since this 1430 never leaked (nor the cartridges) I was a bit puzzled by this "empty cartridge" problem. I refilled the two offending cartridges; I printed about 5 11x19 prints; I'll leave the printer "On" as usual and see tomorrow morning what is the level of the two cartridges. I recall having the black cartridge leaking a bit one time but afterward, everything went back to normal. I cleaned the "pads" as per video instructions from Inkjet Mall; I saw that the pad underneath the print head array was full of ink but never thought that it would be from emptying cartridges?!? I'll see tomorrow Thanks again Jacques Caron Photographe jacques.caron@... Le 2015-07-07 à 18:44, "Paul Roark roark.paul@... [DigitalBlackandWhiteThePrint]" <DigitalBlackandWhiteThePrint@yahoogroups.com> a écrit :
> > Very odd. I've never seen that on the two 1400s I've had for years. I would have guessed the reservoir plugs were not sealing. When I have the reservoie plugs out for filling a couple of my carts will leak badly unless I have the outlets plugged with one of the metal plugs MIS at least used to have/sell. > > Paul > www.PaulRoark.com > > On Tue, Jul 7, 2015 at 12:29 PM, jacques.caron@videotron.qc.ca [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote: > > > Hi I'm using an Epson 1430 with EB6 standard inks; my problem : I fill all the cartridges but… two days later, without printing, the black and "yellow" cartridge are empty??? > > > > Should I change the cartridge for new ones or is there something else that I'M missing? > > Many thanks > > > > >
