Digital BW, The Print
Understanding Color Curves and Ink Interactions
2013-02-05 by remononaz1
I created an acv curve that works very well with the full UT14 ink set on glossy papers. When I developed the curve, I began with a Paul Roark curve and tweaked the blue channel, which after some adjustments controls surface defects caused by the Eboni ink on gloss paper very well.
I had thought that the curve was controlling the amount of Eboni put down, but after reading the article on 2K-2LK ink, I noted the statement that, "blue controls yellow".
Am I incorrect on my assumptions about controlling the black and actually just putting more GLOP on the black areas, using the yellow cartridge of the UT14 set? A screen shot of the curve is available at http://sdrv.ms/Wsi19D.
Re: [Digital BW] Understanding Color Curves and Ink Interactions
2013-02-05 by Paul Roark
When using Photoshop curves, the amount of the K position ink used is
controlled by the combination of the color curves.  If only 2 of the three
curves are full on and the third color is totally off, no K will be
injected.  As the third ink is turned on, more K is injected.  When and
only when all inks are full on will nothing but K be injected.
Paul
www.PaulRoark.com
