Leading Curves In Photoshop Element's 11
2013-02-05 by Robert Fletcher
Hello, I have downloaded Paul's curves unzip the file and moved them into the elements curves folder. I have looked in my manual and search the Internet but I cannot get it any explanation of how to load the curves. Can someone give me the basic navigation route through the menus where I can select the appropriate curves. Thanks in advance, Robert
2013-02-05 by remononaz1
Robert: I don't use Photoshop Elements, I use CS4, but I think they may be similar. For CS4, the instructions to load a curve are: "Open your image and convert it for black and white as you see fit, or open an existing black and white file that is ready to print. Change the image mode to RGB. Go to adjustments > curves and apply the preset curve RRAPG_neutral-2.acv. This will make your image very blue. This is normal." Note that in the curves panel there is a little icon that looks like a sheet of paper (sort of!). You need to click on this icon to open the drop downs where you can find the curve you placed in your folders. I think this misleads a lot of folks. Good luck. Homer Shannon --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Robert Fletcher wrote:
> > Hello, I have downloaded Paul's curves unzip the file and moved them > into the elements curves folder. I have looked in my manual and search > the Internet but I cannot get it any explanation of how to load the > curves. Can someone give me the basic navigation route through the menus > where I can select the appropriate curves. > > Thanks in advance, Robert >
2013-02-06 by Robert Fletcher
Hi Homer Thank you for your suggestions, Photoshop Elements do present a particular challenge when trying to use curves. I've spent quite a bit of time and I must say quite a bit of paper using the adjustments in the Epsom driver. This is the approach I will now take as the results are to my satisfaction and that is the main thing. Thank you for taking your time to reply to me. Robert... On 05/02/2013 17:41, remononaz1 wrote: > > Robert: > > I don't use Photoshop Elements, I use CS4, but I think they may be > similar. For CS4, the instructions to load a curve are: > > "Open your image and convert it for black and white as you see fit, or > open an existing black and white file that is ready to print. Change > the image mode to RGB. Go to adjustments > curves and apply the preset > curve RRAPG_neutral-2.acv. This will make your image very blue. This > is normal." > > Note that in the curves panel there is a little icon that looks like a > sheet of paper (sort of!). You need to click on this icon to open the > drop downs where you can find the curve you placed in your folders. I > think this misleads a lot of folks. > > Good luck. > > Homer Shannon > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com>, Robert > Fletcher wrote: > > > > Hello, I have downloaded Paul's curves unzip the file and moved them > > into the elements curves folder. I have looked in my manual and search > > the Internet but I cannot get it any explanation of how to load the > > curves. Can someone give me the basic navigation route through the > menus > > where I can select the appropriate curves. > > > > Thanks in advance, Robert > > > > [Non-text portions of this message have been removed]
