Digital BW, The Print
Problem with NEF Files
2010-09-15 by mbrouphy
Has anyone ever had a problem with NEF files turning blue/cyan and/or turning part of the image black and the other part blue/cyan?
The presentation of the problem is this:
1- When a given folder is opened in CS4 Bridge the images look fine.
2- After the files are all displayed then the images take on a cyan/blue cast all over or one part of the image, ie the lower half, will go black and the upper half then takes on the cast.
Considerations:
1- Not all of the NEF files do this and are displayed perfectly fine.
2- This did not occur for some time after I downloaded the images off of the card.  And, for those who ask, I did not make a backup of the images. ME BAD!
3- This issue occurs in the display of images in other software, ie Irfanview, also.
4- These are the only RAW files that the anomaly occurs with. CR2 and MRW files are just fine.
5- The camera is a Nikon E8800 and it does have the most recent firmware build installed.
I found nothing on the Nikon site to even remotely address this issue. Any thoughts and ideas are appreciated.
Thanks, Mike
Re: [Digital BW] Problem with NEF Files
2010-09-15 by Paul Grant
What happens if you convert them to dng?
> Considerations:
> Thanks, Mike
Re: Problem with NEF Files
Paul,  As I'm not sure if I did the dng conversions before or after I noticed this problem I don't know if I can really trust those files.
However, I downloaded ViewNX2 from the nikonusa website and the files in my primary target folder are fully viewable.  So, there's some weird stuff happening.  I'm now in the process of downloading the trial version of NX2 and will see what, if any, problems I find duplicated compared to CS4.
Thanks for your interest and willingness to help...Mike
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Paul Grant <studiopbg@...> wrote:
> Sent from my iPhone
> > Considerations:
> > Thanks, Mike
Re: [Digital BW] Re: Problem with NEF Files
Sometimes I have seen that happen with my Canon files in lightroom.    Most always the files are fine it is just the lightroom previews that are corrupt.
Paul
> > Sent from my iPhone
> > > Considerations:
> > > Thanks, Mike
2010-09-15 by Mark Savoia
Mike, what does this have to do with DigitalBlackandWhiteThePrint? Isn't this very OT? At least mark it OT ;)
Mark
http://www.stillrivereditions.com
> Considerations:
> Thanks, Mike
Re: [Digital BW] Problem with NEF Files (OT - by request)
Mark,
I don't find it a serious stretch to address file issues when the end results will be a b/w image.  Everyone that I know that understands half of what they are doing shot in color and convert the image into an RGB b/w image.  If not, then they get what they deserve.  That said, this is a issue of problems found in working with the digital negative, so to speak, for that what the original captured image is.  If this was a traditional film based forum, then this questions wouldn't be raised.
But, if it makes you feel better, then I'll mark it OT.  Okay? Mike
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Savoia <mark@...> wrote:
> Mark
> > Considerations:
> > Thanks, Mike
