input 9/10
2003-11-14 by sirius9x
Is it possible to connect a simple tom pad and a simple cymbal pad to input 9/10 and control them separately (playing different sounds)? What do I need? Thanks for all answers
2003-11-14 by liberatusvirus
--- In DTXpress@yahoogroups.com, "sirius9x" <4dddd@w...> wrote: > Is it possible to connect a simple tom pad and a simple cymbal pad to > input 9/10 and control them separately (playing different sounds)? > What do I need? > > Thanks for all answers If I do the job correctly, you shouldn't need any more answers. Yes, you can connect a mono cymbal and a mono tom to 9/10. Use a mono cable out from each into a TRS splitter, or "Y" adapter, which has two mono female leads to accept your tom and cymbal cables and a single stereo male connector at the base of the "Y" for the 9/10 input. (Do not use a splitter that has dual stereo ends; you will not get one of your components to work.) Then just set the respective voices and triggers for the two pads. If you use a stereo pad in 9/10, like the 65S variety of snare and cymbal, you will not get a rim voice, since 9/10 cannot accommodate the rim switch that makes these pads "stereo." However, instead of two mono pads, you could use another company's dual-zone pad (Yamaha doesn't make anything that corresponds, except the BP80 bar pad), which typically feature a bow and bell for a cymbal or a rim and body for a snare. Only one dual-zone component will work in 9/10 at a time; it's like having two independent mono pads. Ed
--- In DTXpress@yahoogroups.com, rdamon@m... wrote: > Another option to buying a splitter is to use the built-in splitter in the > KP65. Plug the mono pad into the KP65 and the KP65 into zones 9/10. That > will leave you with a stereo input in zone 1. You can then uses a stereo > cymbal (pad/rim) in zone 1. This will allow adding a mono TP65 and a stereo > PCY65S pad to the kit without using a splitter cable. OGD, Can you believe it (I certainly can)? After all this time, I still left something out. That's the last time I challenge myself. Drumb and Drumber, indeed. Ed
2003-11-14 by rdamon@mckinney-usa.com
Another option to buying a splitter is to use the built-in splitter in the KP65. Plug the mono pad into the KP65 and the KP65 into zones 9/10. That will leave you with a stereo input in zone 1. You can then uses a stereo cymbal (pad/rim) in zone 1. This will allow adding a mono TP65 and a stereo PCY65S pad to the kit without using a splitter cable. OGD > -----Original Message----- > From: liberatusvirus [SMTP:liberatusvirus@...] > Sent: Friday, November 14, 2003 9:11 AM > To: DTXpress@yahoogroups.com > Subject: [DTXpress] Re: input 9/10 > > --- In DTXpress@yahoogroups.com, "sirius9x" <4dddd@w...> wrote: > > Is it possible to connect a simple tom pad and a simple cymbal pad > to > > input 9/10 and control them separately (playing different sounds)? > > What do I need? > > > > Thanks for all answers > > If I do the job correctly, you shouldn't need any more answers. Yes, > you can connect a mono cymbal and a mono tom to 9/10. Use a mono > cable out from each into a TRS splitter, or "Y" adapter, which has > two mono female leads to accept your tom and cymbal cables and a > single stereo male connector at the base of the "Y" for the 9/10 > input. (Do not use a splitter that has dual stereo ends; you will not > get one of your components to work.) Then just set the respective > voices and triggers for the two pads. > > If you use a stereo pad in 9/10, like the 65S variety of snare and > cymbal, you will not get a rim voice, since 9/10 cannot accommodate > the rim switch that makes these pads "stereo." However, instead of > two mono pads, you could use another company's dual-zone pad (Yamaha > doesn't make anything that corresponds, except the BP80 bar pad), > which typically feature a bow and bell for a cymbal or a rim and body > for a snare. Only one dual-zone component will work in 9/10 at a > time; it's like having two independent mono pads. > > Ed > > > > Yahoo! Groups Sponsor > ADVERTISEMENT > Click to learn more... > <http://rd.yahoo.com/SIG=12cr6kaj2/M=243273.4156324.5364586.1261774/D=egro > upweb/S=1705031972:HM/EXP=1068905503/A=1750744/R=0/*http://servedby.advert > ising.com/click/site=552006/bnum=1068819103172690> > > <http://us.adserver.yahoo.com/l?M=243273.4156324.5364586.1261774/D=egroupm > ail/S=:HM/A=1750744/rand=804226357> > > Community email addresses: > Post message: DTXpress@yahoogroups.com > Subscribe: DTXpress-subscribe@yahoogroups.com > Unsubscribe: DTXpress-unsubscribe@yahoogroups.com > List owner: DTXpress-owner@yahoogroups.com > > Shortcut URL to this page: > <http://groups.yahoo.com/group/DTXpress> > > Alternate DTXpress site: > <http://www.dtxpressions.com> > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service > <http://docs.yahoo.com/info/terms/>. > ________________________________________________________________________ > This email has been scanned for all viruses by the MessageLabs Email > Security System. For more information on a proactive email security > service working around the clock, around the globe, visit > <http://www.messagelabs.com> > ________________________________________________________________________ > ************************************************************************** The information transmitted herewith is sensitive information intended only for use to the individual or entity to which it is addressed. If the reader of this message is not the intended recipient, you are hereby notified that any review, retransmission, dissemination, distribution, copying or other use of, or taking of any action in reliance upon, this information is strictly prohibited. If you have received this communication in error, please contact the sender and delete the material from your computer. ________________________________________________________________________ This email has been scanned for all viruses by the MessageLabs Email Security System. For more information on a proactive email security service working around the clock, around the globe, visit http://www.messagelabs.com ________________________________________________________________________
2003-11-16 by oldguydrummer
--- In DTXpress@yahoogroups.com, "sirius9x" <4dddd@w...> wrote: > Is it possible to connect a simple tom pad and a simple cymbal pad to > input 9/10 and control them separately (playing different sounds)? > What do I need? > > Thanks for all answers Even another option: Buy the splitter cable and move your Tom3 TP65 mono pad from zone 5 to zone 9 and move your Ride1 PCY65 mono pad from zone 6 to zone 10. This will leave you with one stereo zone 5 and one Stereo (3-zone) Zone 6. Then the Zone 5 could be used with any stereo cymbal or pad. Just remember that on the base DtxpressII module it does not have choking capabilities on zone 5, if you choose to use it with a stereo cymbal pad like the PCY65S/PCY80S. You could then use Zone 6, which has the ability to choke, with a PCY65S Cymbal pad. It could also be used with the soon to be release PCY150S three zone cymbal (bell/bow/edge) cymbal pad to add a three zone pad to your kit. Zone 6 could also be used with a TP65S, so that you could add three sounds (pad,rim1,rim2) OGD
2003-11-18 by Nick Carroll
Hey, Ed (or anyone!) - I am happy to use a Y-splitter on my 9/10 input to connect to separate pads. But my problem is that no retailer I know of stocks them here in Adelaide, Australia. I have had to make do with a Y-splitter that goes from a stereo "phono" plug to two mono "RCA" sockets, on which I have to add two adaptors. It's not the best setup! Can anyone direct me to an on-line store, so I can order the Real McCoy? --- In DTXpress@yahoogroups.com, "liberatusvirus" <liberatusvirus@y...> wrote: > --- In DTXpress@yahoogroups.com, rdamon@m... wrote: > > Another option to buying a splitter is to use the built-in splitter > in the > > KP65. Plug the mono pad into the KP65 and the KP65 into zones 9/10. > That > > will leave you with a stereo input in zone 1. You can then uses a > stereo > > cymbal (pad/rim) in zone 1. This will allow adding a mono TP65 and
> a stereo > > PCY65S pad to the kit without using a splitter cable. > > OGD, > > Can you believe it (I certainly can)? After all this time, I still > left something out. That's the last time I challenge myself. Drumb > and Drumber, indeed. > > Ed
2003-11-18 by emf
--- In DTXpress@yahoogroups.com, "Nick Carroll" <njcarroll56@y...> wrote: > Hey, Ed (or anyone!) - I am happy to use a Y-splitter on my 9/10 > input to connect to separate pads. But my problem is that no > retailer I know of stocks them here in Adelaide, Australia. I have > had to make do with a Y-splitter that goes from a stereo "phono" > plug to two mono "RCA" sockets, on which I have to add two adaptors. > It's not the best setup! Can anyone direct me to an on-line store, > so I can order the Real McCoy? Nick, Drumbalaya.com sells the Hosa version, YPP117. I'm willing to bet that Musiansfriend, zzounds, SameDayMusic, et al. will have them, too. The only problem will be to find out which one has the best shipping policy to Australia. It's a small item. Any online stores down under? Ed
2003-11-19 by ozteevan
> > Hey, Ed (or anyone!) - I am happy to use a Y-splitter on my 9/10 > > input to connect to separate pads. But my problem is that no > > retailer I know of stocks them here in Adelaide, Australia. Hi Nick I think I have found a lead at Venue Music in Sydney with free delivery anywhere in Australia!! Check out: http://www.venuemusic.com.au/Products.asp?ProdID=3164 I have not used one of these leads but it sounds like it is the right type. Roger
2003-11-19 by emf
--- In DTXpress@yahoogroups.com, "ozteevan" <ozteevan@y...> wrote: > > > Hey, Ed (or anyone!) - I am happy to use a Y-splitter on my 9/10 > > > input to connect to separate pads. But my problem is that no > > > retailer I know of stocks them here in Adelaide, Australia. > > Hi Nick > > I think I have found a lead at Venue Music in Sydney with free > delivery anywhere in Australia!! Check out: > http://www.venuemusic.com.au/Products.asp?ProdID=3164 > > I have not used one of these leads but it sounds like it is the right > type. Roger, NIce find. Given the male connectors at the split, it's more an insert cable than an adapter, but the runs seem to be long enough. Thanks to you, NIck should be in business. Ed
2003-11-25 by Nick Carroll
A belated thank you, Roger. I may need two of those cables
and a male-to-male adaptor, but it's a start!
(Cable 1) (Cable 2)
MODULE =========------(ADAPTOR)------========BAR PAD
---PAD /
9/10
> Hi Nick
right > type. > > Roger
2004-06-16 by vap19592000
Hello every one. My name is Bobby, and I am new to the group. I recently purchased the DTXpress2. I know there has been many posts regarding the subject on "input 9/10 connections" Here is another one. I will be using a Y STEREO cable (stereo in, mono x 2 out) and plug it into input 9/10. Mono A to pad A, mono B to pad B. How/where do I go to to assign the pads?? I wish to connect 2 pads for 2 different sounds using input 9/10. It seems when I have completed the above steps, I receive the SAME sound on BOTH pads.
2004-06-17 by emf
--- In DTXpress@yahoogroups.com, "vap19592000" <vap19592000@y...> wrote: > Hello every one. My name is Bobby, and I am new to the group. I > recently purchased the DTXpress2. > I know there has been many posts regarding the subject on "input 9/10 > connections" > Here is another one. I will be using a Y STEREO cable (stereo in, > mono x 2 out) and plug it into input 9/10. Mono A to pad A, mono B to > pad B. How/where do I go to to assign the pads?? I wish to connect 2 > pads for 2 different sounds using input 9/10. > It seems when I have completed the above steps, I receive the SAME > sound on BOTH pads. Off the top of my head, my guess is that your "Y" adaptor is actually stereo at each end. What you need is a true TRS splitter, which breaks down as you wrote above. Check to make sure that you have one. If the adaptor is correct, the pads should split into 9 and 10 naturally when you strike them and carry their own parameters. Otherwise, you access only one input.
