How To Hook Up MIDI Converter...TMC-6
2003-01-31 by jadiebooshkie <jadiebooshkie@yahoo.com>
Just wondering if I got the Roland TMC-6...how would I hook it to the DTXII brain...would MIDI OUT on the TMC-^ plug into the MIDI IN on the DTX?...I am assuming it would run off or in conjunction with the DTX module...is this so?
2003-01-31 by liberatusvirus <liberatusvirus@yahoo.com>
Jade, You'd do it through a MIDI hookup. The first step would be to transfer sounds from the DTX module to the TMC-6's individual inputs (with the pads connected to them) via MIDI-in, probably by hitting pads on your kit that have voices saved to particular user note numbers, which the TMC-6 can store. From that point on, until you change it, the TMC-6 uses each of those note numbers/inputs to access your selected voice (or voices, if the input is stereo) in the DTX via MIDI-out whenever the appropriate pad is hit. Once you've programmed the sounds, you set up the triggering functions on the TMC-6 (gain etc) to your liking. Voila, now you can play. The TMC-6 functions like an intermediary, an electronic drum broker, between the extra pads and the DTX module, which supplies the sounds. Those are the nuts and bolts of a MIDI interface. The details of how the TMC-6 accomplishes its job will have to be between you and the manual. --- In DTXpress@yahoogroups.com, "jadiebooshkie <jadiebooshkie@y...>" <jadiebooshkie@y...> wrote: > Just wondering if I got the Roland TMC-6...how would I hook it to > the DTXII brain...would MIDI OUT on the TMC-^ plug into the MIDI IN > on the DTX?...I am assuming it would run off or in conjunction with > the DTX module...is this so?
2003-01-31 by deb maniace
So what you are saying is that the Trigger Edits that say "Save to input x or y" will then be transferred to each individual input on the TMC-6? Say I saved a crash cymbal setting on the DTX to input 7...I would then take the input 7(saved crash settings) and transfer them to say input 3 on the Roland? Then I could plug in an x-tra crash to input 3 on the Roland...hit the crash pad(that is plugged into #3 on the Roland) and those settings from the DTX #7 input will be reproduced and transfered to #3 crash pad on the Roland?////Sorry I SEEM SO DENSE...this is all NEW stuff to me... and ..oh yah...I may have a KITI...see my post earlier...heard from Rezdrums, if this doesn't pan out I will probably go with the Roland....Jade --- "liberatusvirus <liberatusvirus@...>" <liberatusvirus@...> wrote: > Jade, > > You'd do it through a MIDI hookup. The first step > would be to > transfer sounds from the DTX module to the TMC-6's > individual inputs > (with the pads connected to them) via MIDI-in, > probably by hitting > pads on your kit that have voices saved to > particular user note > numbers, which the TMC-6 can store. From that point > on, until you > change it, the TMC-6 uses each of those note > numbers/inputs to > access your selected voice (or voices, if the input > is stereo) in > the DTX via MIDI-out whenever the appropriate pad is > hit. Once > you've programmed the sounds, you set up the > triggering functions on > the TMC-6 (gain etc) to your liking. Voila, now you > can play. The > TMC-6 functions like an intermediary, an electronic > drum broker, > between the extra pads and the DTX module, which > supplies the > sounds. Those are the nuts and bolts of a MIDI > interface. The > details of how the TMC-6 accomplishes its job will > have to be > between you and the manual. > > > --- In DTXpress@yahoogroups.com, "jadiebooshkie > <jadiebooshkie@y...>" <jadiebooshkie@y...> wrote: > > Just wondering if I got the Roland TMC-6...how > would I hook it to > > the DTXII brain...would MIDI OUT on the TMC-^ plug > into the MIDI > IN > > on the DTX?...I am assuming it would run off or in > conjunction > with > > the DTX module...is this so? > > __________________________________________________ Do you Yahoo!? Yahoo! Mail Plus - Powerful. Affordable. Sign up now. http://mailplus.yahoo.com
2003-01-31 by Walt
Hi Jade, Although my experience is with a PM-16, not a TMC-6, I suspect the theory is the same. A trigger to Midi interface device converts a pad hit to MIDI information, then sends it to another device to process. On the PM-16 what I did was to assign a MIDI note number (plus some other stuff) to each of the pads directly attached to it. Then, on the DTX you define a sound that is associated with each of the MIDI note numbers you assigned on the PM-16. The result was that you hit a pad attached to the interface, the interface converts that to a MIDI note number to be played, and sends that to the DTX module. The DTX module determines what sound is assigned to that MIDI note number, and sends it off to the tone generator to play. I expect that the TMC-6 works the same, although the way you assign the MIDI info on it may be a little different than the PM-16. Walt --- deb maniace <jadiebooshkie@...> wrote: > > > So what you are saying is that the Trigger Edits > that > say "Save to input x or y" will then be transferred > to > each individual input on the TMC-6? Say I saved a > crash cymbal setting on the DTX to input 7...I would > then take the input 7(saved crash settings) and > transfer them to say input 3 on the Roland? Then I > could plug in an x-tra crash to input 3 on the > Roland...hit the crash pad(that is plugged into #3 > on > the Roland) and those settings from the DTX #7 input > will be reproduced and transfered to #3 crash pad on > the Roland?////Sorry I SEEM SO DENSE...this is all > NEW > stuff to me... and ..oh yah...I may have a > KITI...see > my post earlier...heard from Rezdrums, if this > doesn't > pan out I will probably go with the Roland....Jade > --- "liberatusvirus <liberatusvirus@...>" > <liberatusvirus@...> wrote: > > Jade, > > > > You'd do it through a MIDI hookup. The first step > > would be to > > transfer sounds from the DTX module to the TMC-6's > > individual inputs > > (with the pads connected to them) via MIDI-in, > > probably by hitting > > pads on your kit that have voices saved to > > particular user note > > numbers, which the TMC-6 can store. From that > point > > on, until you > > change it, the TMC-6 uses each of those note > > numbers/inputs to > > access your selected voice (or voices, if the > input > > is stereo) in > > the DTX via MIDI-out whenever the appropriate pad > is > > hit. Once > > you've programmed the sounds, you set up the > > triggering functions on > > the TMC-6 (gain etc) to your liking. Voila, now > you > > can play. The > > TMC-6 functions like an intermediary, an > electronic > > drum broker, > > between the extra pads and the DTX module, which > > supplies the > > sounds. Those are the nuts and bolts of a MIDI > > interface. The > > details of how the TMC-6 accomplishes its job will > > have to be > > between you and the manual. > > > > > > --- In DTXpress@yahoogroups.com, "jadiebooshkie > > <jadiebooshkie@y...>" <jadiebooshkie@y...> wrote: > > > Just wondering if I got the Roland TMC-6...how > > would I hook it to > > > the DTXII brain...would MIDI OUT on the TMC-^ > plug > > into the MIDI > > IN > > > on the DTX?...I am assuming it would run off or > in > > conjunction > > with > > > the DTX module...is this so? > > > > > > > __________________________________________________ > Do you Yahoo!? > Yahoo! Mail Plus - Powerful. Affordable. Sign up > now. > http://mailplus.yahoo.com > __________________________________________________ Do you Yahoo!? Yahoo! Mail Plus - Powerful. Affordable. Sign up now. http://mailplus.yahoo.com
--- In DTXpress@yahoogroups.com, Walt <wgardus@y...> wrote: > Hi Jade, > > Although my experience is with a PM-16, not a TMC-6, I > suspect the theory is the same. > > A trigger to Midi interface device converts a pad hit > to MIDI information, then sends it to another device > to process. On the PM-16 what I did was to assign a > MIDI note number (plus some other stuff) to each of > the pads directly attached to it. Then, on the DTX > you define a sound that is associated with each of the Oh Yah....I remember now!! I recall reading the post about the MIDI note numbers when you voice edit on the DTX. I suspect I will need ALOTTA HELP...bear with me guys!!...Thanx Walt....Jade MIDI note numbers you assigned on the PM-16. The
> result was that you hit a pad attached to the > interface, the interface converts that to a MIDI note > number to be played, and sends that to the DTX module. > The DTX module determines what sound is assigned to > that MIDI note number, and sends it off to the tone > generator to play. > > I expect that the TMC-6 works the same, although the > way you assign the MIDI info on it may be a little > different than the PM-16. > > Walt > > --- deb maniace <jadiebooshkie@y...> wrote: > > > > > > So what you are saying is that the Trigger Edits > > that > > say "Save to input x or y" will then be transferred > > to > > each individual input on the TMC-6? Say I saved a > > crash cymbal setting on the DTX to input 7...I would > > then take the input 7(saved crash settings) and > > transfer them to say input 3 on the Roland? Then I > > could plug in an x-tra crash to input 3 on the > > Roland...hit the crash pad(that is plugged into #3 > > on > > the Roland) and those settings from the DTX #7 input > > will be reproduced and transfered to #3 crash pad on > > the Roland?////Sorry I SEEM SO DENSE...this is all > > NEW > > stuff to me... and ..oh yah...I may have a > > KITI...see > > my post earlier...heard from Rezdrums, if this > > doesn't > > pan out I will probably go with the Roland....Jade > > --- "liberatusvirus <liberatusvirus@y...>" > > <liberatusvirus@y...> wrote: > > > Jade, > > > > > > You'd do it through a MIDI hookup. The first step > > > would be to > > > transfer sounds from the DTX module to the TMC-6's > > > individual inputs > > > (with the pads connected to them) via MIDI-in, > > > probably by hitting > > > pads on your kit that have voices saved to > > > particular user note > > > numbers, which the TMC-6 can store. From that > > point > > > on, until you > > > change it, the TMC-6 uses each of those note > > > numbers/inputs to > > > access your selected voice (or voices, if the > > input > > > is stereo) in > > > the DTX via MIDI-out whenever the appropriate pad > > is > > > hit. Once > > > you've programmed the sounds, you set up the > > > triggering functions on > > > the TMC-6 (gain etc) to your liking. Voila, now > > you > > > can play. The > > > TMC-6 functions like an intermediary, an > > electronic > > > drum broker, > > > between the extra pads and the DTX module, which > > > supplies the > > > sounds. Those are the nuts and bolts of a MIDI > > > interface. The > > > details of how the TMC-6 accomplishes its job will > > > have to be > > > between you and the manual. > > > > > > > > > --- In DTXpress@yahoogroups.com, "jadiebooshkie > > > <jadiebooshkie@y...>" <jadiebooshkie@y...> wrote: > > > > Just wondering if I got the Roland TMC-6...how > > > would I hook it to > > > > the DTXII brain...would MIDI OUT on the TMC-^ > > plug > > > into the MIDI > > > IN > > > > on the DTX?...I am assuming it would run off or > > in > > > conjunction > > > with > > > > the DTX module...is this so? > > > > > > > > > > > > __________________________________________________ > > Do you Yahoo!? > > Yahoo! Mail Plus - Powerful. Affordable. Sign up > > now. > > http://mailplus.yahoo.com > > > > > __________________________________________________ > Do you Yahoo!? > Yahoo! Mail Plus - Powerful. Affordable. Sign up now. > http://mailplus.yahoo.com
