Each drum (pad) to a unique track using Tascam USB122 and Cubasis VST
2004-08-14 by hinckc
Hello everyone!
I'm trying to get recommendations on how to configure my current
setup such that I can record each drum to a separate track on my
Cubasis VST recording setup.
Here's how things are configured, more or less...  The primary
objective of how it's setup is to allow all instruments to play
simultaneously during practice sessions, and to allow one instrument
at a time to record to the PC.
I've got the following equipment:
AX-212 Amp
Tascam 4 port cassette recorder acting as a mixer
Fender electric guitar (to the guitar in on the Ax-212)
Yamaha Electric Piano (to the Tascam Line-In)
Yamaha DTExpress 2.0 audio out (to the Tascam Line-in) (midi out/in
to the USB-122 on the recording PC)
Line6 POD (mono out to the Tascam line-in)
Mic (to the last Tascam line-in)
And Finally, the Tascam line-out goes to the AX-212 Aux-in for
amplification, allowing me to play to the everything to the room
through the AX-212 (for live practice).
For recording, I take the line out from the AX-212 to the USB-122 to
record on the PC. With this line, I can record the audio out from
any instrument in my setup.
And audio recording works wonderfully.
What I'm trying to setup now is midi from the DTxpress.
For recording, I've got local=off, on my dtxpress, and my USB-122
Midi port is echoing my notes back perfectly during my original
recording session. (sync seems ok.  latency, too)
However, all the midi records to one track (I've got that track set
to record from "any" midi channel), and I want them to show
up as the drum pad I hit, vs. a note, that isn't actually labeled as
what I hit.  I'd also like to be able to record each drum to a
different track in Cubasis VST.
Is this possible?  I haven't found any documentation that shows how
to set this up, so I wonder if I'm just dreaming.
I'm guessing that the way to configure this is to put each pad that
I'm using on a separate midi channel, then enable each track in my
s/w to record that channel.  Am I offbase?
How do I save that config on my DTXpress?  Will that require a full
dump of the sysex, or can I just save that as a drumkit?
If the best you can do is to recommend a good book on the general
topic, I'd be glad to get that feedback as well!
Maybe this is more of a question for a cubasis or USB122 group, but
I've read info on this group some time, and this group gives better
feedback than most!
Thanks!
-Chris
Re: Each drum (pad) to a unique track using Tascam USB122 and Cubasis VST
2004-08-14 by emf
Hi Chris,
I'm answering this one pretty much because I have to do some work on
my computer today, and I welcome any distraction. I don't use Cubase,
so I can't get to nuts and bolts. But I agree with your guess: Record
each pad to a separate MIDI track on the sequencer. You can change
the pad assignments in the voice edit menu. Try that. As far as
saving the result is concerned, why not save it as a song on the
DTXpress sequencer? Check the song section in the manual.
Ed
