Index last updated: 2026-03-31 01:49 UTC
Rechannelize MIDI in ?
2001-12-12 by erik_magrini@Baxter.com
Does the glitching happen when you're playing back the patterns, or is it
just the display flickering or something when you scroll the data wheel in
stop mode?  I keep mine to Rechannelize Always too, never seen anything
weird though.
The only other concern I have is when I set a particular channel to have
an FX send to main and at the same time have the "RECHANNELIZE MIDI IN to
Chan:" set to "always" and I exit the MIDI edit and scroll through my
tracks I get pauses and glitches switching inbetween tracks.  Setting
Rechann...chan: to "off" solves the issue. Trying to see the routing
logical reasoning... hmm..
Re: [xl7] Rechannelize MIDI in ?
2001-12-12 by Kamy
I get the same glitshes by setting Rechannalize Midi In other than to
"off", when I use the Arps.
Kamy
weird though.
The only other concern I have is when I set a particular channel to have an
Chan:" set to "always" and I exit the MIDI edit and scroll through my tracks
Rechann...chan: to "off" solves the issue. Trying to see the routing logical
reasoning... hmm..
