E-loader problems
2003-07-22 by r3gu
I'm using Windows 2000 and the MP7 is connected througt Edirol UM-1 to computer (Midi IN and A OUT). e-loader recognizes the mp7 if i test it, midi monitor gets messages from it, and it "sees" all the patterns in MP7..but, when i try to save my patterns, it thinks for a sec and then tells that "there was an error..blahblah"... what could be the problem? and how do i use the USB-connection?, when i insert it, it sees USB composite device and asks for a driver (which should'nt be needed?) and then takes the device out of current configuration because the driver does not exist... if i remember correctly, i did get them out using Win98 SE.. does any1 else use win2000 with e-loader?
