How can I change my samplers patch from the Xl-7?
2003-07-20 by sincultura13
Say, I want to use the patch #14 in my external sound module... Can I
change it to #14 from the Xl-7? I have a sampler that for some reason
doesn't route the incoming midi signal to the patch you are currently
using...
Can someone redirect me to the right page in the manual or guide me
through the process?
I've been looking around the manual for about an hour to no avail...
Btw, I'm not complaning about the manual most things are really
clearly explained, I just kind find where this patch thing it at...
thanks in advance...
Re: [xl7] Re: How can I change my samplers patch from the Xl-7?
2003-07-21 by erik_magrini@Baxter.com
You also need to make sure the track is set to EXT (Pattern Edit menu),
and that there is a program change event on that track as well.
sincultura13 <sincultura13@...>
07/21/2003 11:35 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: How can I change my samplers patch from the Xl-7?
Last night I read old posts here and followed the steps but it didn't
work...  I don't know what I hit yesterday but once I was able to
change the patch to another but not the one I needed. :( I think
might be confusing terms or something....Any help greatly appreciated.
I
reason
currently
> using...
avail...
2003-07-21 by sincultura13
Thanks! I could have sworn that I tried that yesterday... but it
worked today.... Now, the problem I have is that the pads send an on
messege to trigger the loop but instead of turn it off when I hit the
pad again it retriggers it.... Is there a way to change that?
thanks again
menu),
> rEalm
> sincultura13 <sincultura13@y...>
> 07/21/2003 11:35 AM
>         cc:
didn't
appreciated.
Can
> I
> reason
> currently
> > using...
me
> avail...
at...
That would be a setting in your sampler, what kind is it?
Now, the problem I have is that the pads send an on messege to trigger the
loop but instead of turn it off when I hit the pad again it retriggers
The sampler is a Boss SP-505... though it has a very poor midi
implimentation I've never had any problems with this before. I've had
it for a long time and the first things I checked was all the
settings, but it shouldn't be 'cuz I externally trigger samples all
the time... It's like the Sp-505 doesn't know what to do with the
incomming signal... if I bounce pads on the Xl-7 a certain way they
stop the loops but is really innacurate... I only really need the
pads to trigger single shots, but I still would like understand why
this happends...
> rEalm
trigger the
retriggers
2003-07-22 by erik_magrini@Baxter.com
I'm guessing the midi implementation on the sp505 is probably identical to
that on the sp808 (which I have).  Again, I still think this is a sampler
setting, there should be away to change how the pads on the 505 play their
samples, typically with options like: one shot, trigger, drum, repeat,
etc.  The pads on the XL-7 will only ever be able to send out Midi note on
and off messages, and the only option related to them from within the XX-7
itself is the option to keep them from transmitting this data out the midi
port.  Gotta be a sp505 setting.
this happends...
2003-07-22 by Aaron Eppolito
My coworker just dropped a SP-202 on my desk.  Pg 39 in the manual
(Section 6, MIDI) details "Trigger Playback" vs "Gate Playback".  In
trigger mode, each press of a note toggles the sound on and off.  In
gate mode, it behaves like a normal note (note down: sound on, note up:
sound off).
-Aaron
PS. the way you're getting it to work by hitting the pads a certain way
is because you're double triggering the pad.
> had it for a long time and the first things I checked was all the
> all the time... It's like the Sp-505 doesn't know what to do with
> the incomming signal... if I bounce pads on the Xl-7 a certain
> way they stop the loops but is really innacurate... I only really
> need the pads to trigger single shots, but I still would like
> understand why this happends...
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
2003-07-22 by sincultura13
Thanks... Realm,  so you get to sample to play right with
the "repeat" playback option selected for the sample ? My
keyboard/computer does that without a problem... The Sp-505 has
trigger, gate, and drum(single hits) and also the first two have the
option to be looped.
up:
> sound off).
> -Aaron
way
> Do you Yahoo!?
The Sp808 doesn't have that option, I was just throwing out the names of
the most common ones that a lot of samplers have.  I only use GATE mode
with the Sp808.
