Re: [xl7] Audio routing and "hello"
2003-07-02 by Aaron Eppolito
Go to MIX OUTPUT, 7th screen in the Global menu. Note that you have to physically have plugs in the jacks for them to function as external sends. -Aaron --- zerocrossing2001 <zerocrossing2001@...> wrote: > I can't seem to figure out how to route audio to sub1 __________________________________ Do you Yahoo!? SBC Yahoo! DSL - Now only $29.95 per month! http://sbc.yahoo.com
2003-07-02 by erik_magrini@Baxter.com
Also to expand on what Aaron said, if you use the Sub1 Outs as external
sends, they bypass the effects. You can't have something going to the
effects and out of the unit, it's one or the other from what I understand.
07/02/2003 12:59 AM
Please respond to xl7
cc: Subject: [xl7] Audio routing and "hello" Hey, I just picked up an XL-7 and it does seem like a vast box compared to the Roland MC-307 it's replacing. One of the main reasons I purchased it is due to its audio routing capabilities, but boy does the manual seem obtuse! I've upgraded the OS to v2, and gone through the manual and archives but I can't seem to figure out how to route audio to sub1. All I want to do is keep my drum tracks (1-8) in the main out and send the rest of the tracks to sub1 (after the internal effects if that's possible). I used to do this all the time with my Ensonic TS-10 (boy was that a joy to work with! E-MU, can you hear me? Learn from that elegant OS!) but I just spent an hour with the XL-7 manual and I could't seem to make it happen. Thanks, Mark Sottilaro To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ [Non-text portions of this message have been removed]
More expoundings... (is that a word?)
When you insert a plug into a sub jack, only the DRY signal is removed
from the mains. The WET signal will still be present at the mains, but
the send amount can be set to 0% for that send to prevent this.
synth --> send% --> FX --(wet)-> main
\--> if(plugInSub) -(dry)-> sub
else -(dry)-> main
Okay, that little ascii drawing probably made it worse, but in the
manual there's a diagram...
-Aaron
> external sends, they bypass the effects. You can't have
> something going to the effects and out of the unit, it's one or
Do you Yahoo!?
http://sbc.yahoo.com2003-07-02 by mark sottilaro
Ah, OK. That makes sense. Much thanks. Upon more manual reading I actually got a lot out of a diagram that's in there. On one hand, great, on the other, it kind of ruins my idea I had for using the XL-7. My idea was to send drums directly to a mixer, while routing other sounds to an Electrix Repeater so they could be looped in the audio domain and then effected in different ways. Not being able to route a wet signal to the subs means I'd either have to add some multieffects processor to the chain (yet another thing!). I could use a Lexicon MPX1 for that job but I'd lose it for post loop processing, or I could buy another effects processor for the job (not likely at this time due to money and space issues) OR what I'm more likely to do is get my braindead PlanetEarth out of the closet and install ROMS into that so I could run it as a seperate device all together. Not what I was hoping to do, but oh well. Thanks again, Mark --- Aaron Eppolito <synthesis77@...> wrote:
> More expoundings... (is that a word?) > > When you insert a plug into a sub jack, only the DRY > signal is removed > from the mains. The WET signal will still be > present at the mains, but > the send amount can be set to 0% for that send to > prevent this. > > synth --> send% --> FX --(wet)-> main > \ > \--> if(plugInSub) -(dry)-> sub > else -(dry)-> main >
2003-07-02 by delltamale
> > On one hand, great, on the other, it kind of ruins my > idea I had for using the XL-7. My idea was to send > drums directly to a mixer, while routing other sounds > to an Electrix Repeater so they could be looped in the > audio domain and then effected in different ways. > > Not being able to route a wet signal to the subs means > I'd either have to add some multieffects processor to > the chain (yet another thing!). Hi Mark, Or, you could send your >Main< outs to the repeater, and send your drums out the sub. This would require a dry set of drums, though the effects in the emu aren't the most exciting for effecting percussion anyway... Another tip - I everything to the subs left and right, and send them to mono in/stereo out effect processors. This way, I get two mono subs instead of each stereo sub, and can control the effects on each subbed track via pan. I also send the drum tracks to a separate compressor out of sub 2, this makes them stand out from the compressed main mix. bIz
2003-07-03 by robotchas
Further expoundifications: If you insert a mono plug just up to the first click you can feed external audio into the main outs without interrupting Bus2 or Bus3. This is smart design (intentional?) since it allows you to forgo a mixer in a pinch (if you're a live minimalist, or broke - being both, I appreciate this feature) without losing effects busses. However, I notice this is more fiddly than I remember the jacks on my Morpheus being...the slightest wiggle and the insert jacks lose contact. Am I remembering wrong, or are these jacks looser than they used to be? Anyone notice this? A bit frustrating... --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote:
> More expoundings... (is that a word?) > > When you insert a plug into a sub jack, only the DRY signal is removed > from the mains. The WET signal will still be present at the mains, but > the send amount can be set to 0% for that send to prevent this. > > synth --> send% --> FX --(wet)-> main > \ > \--> if(plugInSub) -(dry)-> sub > else -(dry)-> main > > Okay, that little ascii drawing probably made it worse, but in the > manual there's a diagram... > > -Aaron
2003-07-04 by mark sottilaro
Thanks everyone for the good advice. This is surely a deep and complex box with lots of quirks. I'm sure it will keep me up many a night until I master it. With that said, I kind of got it going the way I wanted... but I'm wondering if I should put all my ROMS in one box. I've got the ROM that came with the XL-7, one that came with the Planet Earth, Protozoa and the Beat Garden ROM. Sure I can put them in my XL-7 and have one nice big yellow box, but does that make sense? Should I put some ROMS in the PlanetEarth again? What would I gain? I intend on having some sounds sequenced and some available to play live using a Novation ReMote25 as a triggering device. (btw, as a MIDI controller it rules) --- robotchas <robotchas@...> wrote: > If you insert a mono plug just up to the first >click you can feed external audio into the main >outs without interrupting Bus2 or Bus3. Hosa makes a pretty good stereo male into two mono female 1/4" plugs that would let you not have to deal with dealing with the click issue. Thanks, Mark Sottilaro
Oooo, good idea. So simple it went right by me. I do like a little reverb for ambience on the drums though. Hmmmmm Such a quandry. Might be time to whip out that ROMless PlanetEarth... On the other hand, I was doing what I had hoped to do last night using a KAOSS pad to add some effects to the sub1 out. Worked well for the most part. The KAOSS pad II isn't the best effect device in the world, but for interesting performance effects it can't be bet. (when I add an Alesis AirFX and AirSynth I swear I'm fucking dancing!) Mark --- delltamale <biz@...> wrote:
> Or, you could send your >Main< outs to the repeater, > and send your > drums out the sub. This would require a dry set of > drums, though the > effects in the emu aren't the most exciting for > effecting percussion > anyway... > > Another tip - I everything to the subs left and > right, and send them > to mono in/stereo out effect processors. This way, I > get two mono > subs instead of each stereo sub, and can control the > effects on each > subbed track via pan. > > I also send the drum tracks to a separate compressor > out of sub 2, > this makes them stand out from the compressed main > mix. > > bIz > >
2003-07-04 by Martin Cliffe
It *is* from what I gather from reading the manual an intentional feature... says something like "at a pinch they can serve as extra line inputs" or something along those lines... You can make it a more sturdy solution by building a couple of leads with a mono jack at one end and a stereo jack at the other, and wire the tip from the mono jack to the ring from the stereo one. Or, tear an insert lead in half ;-) This way you can plug the jack in all the way rather than have it half hanging out. Martin --- In xl7@yahoogroups.com, "robotchas" <robotchas@y...> wrote: > Further expoundifications: > > If you insert a mono plug just up to the first click you can feed external audio > into the main outs without interrupting Bus2 or Bus3. This is smart design > (intentional?) since it allows you to forgo a mixer in a pinch (if you're a live > minimalist, or broke - being both, I appreciate this feature) without losing > effects busses. > > However, I notice this is more fiddly than I remember the jacks on my > Morpheus being...the slightest wiggle and the insert jacks lose contact. Am I > remembering wrong, or are these jacks looser than they used to be? Anyone
> notice this? A bit frustrating... > >
