using mp7 as midisequencer with nuendo and asr x pro, problems recording notes?
2003-06-27 by r3gu
Holla! I have a ASR X Pro connected to mp7 from the midi B OUT to asr's midi IN, then i have an Edirol UM-1 midi-interface connected to mp7's midi IN and OUT A. if i try to record midisequences from mp7 to nuendo (midi channel set 1 and rec pressed down on nuendo) it doesn't record any notes at all...still, it records if i play the keyboard at the same time on the mp7. also, if a have made a sequence to some of B tracks, it does not send them to ASR, but it also plays ASR's sounds when i play around the mp7's keyborad. somehow, it seems that the mp7's sequencer is not sending the notes at all. I checked this out also with e-loaders midi monitor, only the "start song" and "end song" messages came to from sequences...but, the keybord send all data when i playd it. How should the midi setup been done in Mp7 to make this work?
