Archive for xl7.
2 new-user questions
2003-06-26 by Brian
I recently bought my XL-7, and just upgraded it to OS 2.0, and I had
2 questions.
The internal sequences were screwed up when I bought it, so I
replaced everything with factory patterns and songs (via E-Loader).
Before I did that, I initialized the unit and ran it through a self-
test. In doing so, I noticed the main ROM was in slot 4, not slot 1.
Is that normal, and if not, will it cause me any problem? (Upon
opening the unit, I found it's closest to the side of the unit).
Also, my checksum for OS 2.0 is ABA794C2. Is that correct? The E-
Loader manual claimed that number would be in the release notes for
me to compare to, but there were no release notes with my OS upgrade.
Brian
Re: [xl7] 2 new-user questions
2003-06-26 by erik_magrini@Baxter.com
The internal sequences were screwed up when I bought it, so I replaced
everything with factory patterns and songs (via E-Loader). Before I did
that, I initialized the unit and ran it through a self-test. In doing so,
I noticed the main ROM was in slot 4, not slot 1. Is that normal, and if
not, will it cause me any problem? (Upon opening the unit, I found it's
>>>I don't think it matters what the actual slot is.  I you can hear
sounds, it's all good. <<<
Also, my checksum for OS 2.0 is ABA794C2. Is that correct? The E- Loader
manual claimed that number would be in the release notes for me to compare
>>>Yeah, they don't give you the checksum it seems like.  Should be fine.
Re: 2 new-user questions
2013-01-16 by igrovo
I can confirm after upgrading mine to 2.0 that I also got the same checksum and everything is working fine.
> rEalm
