It is the same behaviour I had with Windows ME with my developer java
installed. But that package is not on this machine...
UGH
This is the JDK that was downloaded from the sun website. No mods or
special bits.
Bruce
>java -version
java version "1.3.1"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.3.1-b24)
Java HotSpot(TM) Client VM (build 1.3.1-b24, mixed mode)
--- In xl7@y..., Scott Ruda <scottr@e...> wrote:
> on 12/3/01 5:54 PM, bruce@s... at bruce@s... wrote:
> > Anyone been able to get E-Loader to install on Windows XP Pro?
> > Mine fails completely with no message, no warning, no alert. Just
> > takes a dump silently.
> > Bruce
> E-Loader has not been officially tested with Windows XP. I'll have
to get
> that pushed up in the schedule. I guess I was fantasizing thinking
it was
> going to act the same as Win 2000. :-(
> Are you saying the installer fails, or is it E-Loader itself failing
after
> installation?
> Didn't you post once before about problems installing with Windows
XP, but
> then say you resolved your issue by removing some 'developer' Java
VM that
> you were running?
> Scott
