Re: [xl7] REPEAT in LIST
2001-12-03 by erik_magrini@Baxter.com
Gotcha!  I was trying doing it slightly out of order.  I would press
Repeat, then try to scroll to the new event to make my changes.  I thought
the whole "not having two events at thr same location" thing took effect
when you left Pattern Edit mode, oops!  I knew I should have read the
addendum again!  Oh well, you know how it is when you're deep into making
a new track...
Thanx again Aaron!
Bottom line?  Press repeat, edit the event, increment.  Repeat, edit,
increment.
2001-12-03 by Aaron Eppolito
You can only have one event of the same type at the same time in a
track.  For example, you can't have two controller #7 messages at
1.01.001.  When you press repeat in the list editor, you are copying the
current event into a "temporary" event.
Once you've done that, you should edit the event into being what you
want it to be (by changing time, event, or other).  When you increment
to a different event (by using the <-> field or with "spin/enter") the
XL-7 tries to insert that event.  If you haven't edited the event yet,
it remains as a duplicate, and therefore cannot be inserted into the
sequence.
increment.
Enjoy!
  -Aaron
erik_magrini@... wrote:
> I couldn't get the REPEAT thing to work this weekend, it still only
> gave me one event at that location if it was the last event on that
> track. Strange...
