OT: MIDIQuest Rant
2003-06-17 by Brian
This is an off-topic rant about Uniquest that I posted to the usenet a while ago. As I mention at the bottom of the post, Uniquest looks like it is the same codebase as MIDIQuest 9.0. Therefore, a lot of the info I put here _might_ apply to MIDIQuest 9.0 for Windows. ---- Wow. I'm a bit surprised that some software written today still requires a degree in geek. I received a free copy of UniQuest (editor/librarian) for one of my synth modules, and decided to put it through its paces. The entire experience was sour. I'm writing this to alert any potential MIDIQuest/UniQuest customers of what they will likely have to deal with. Problem 1: The packaging that the CD was shipped in is so wordy, you'd think it was a government tax instruction pamphlet. It's a tri- fold, and the "before installation" text comes _after_ the QuickStart text. Problem 2: The CD doesn't have an autorun (for Windows), but rather 16 icons. Nowhere in the manual do they tell you which one to run (it's setup.exe), but to assist you, there are 4 icons to throw you off, including "Install", "Installation Guide - Click me FI..." (truncated from FIRST), "Operation Manual", and "ReadMe". Problem 3: Their AutoSensing MIDI routines are brain dead. Not only do they require you to choose the MIDI ports first, but the manual is wrong since you need to set the MIDI port _twice_ on the same dialog. Oh, and did I mention MIDI In and Out each have a separate dialog? Problem 4: The online manual for UniQuest is 128 pages. The manual for the synth I'm using with UniQuest has a 41 page manual. I guess you pay additional $ for additional confusion. Problem 5: The installer tried to put UniQuest four subdirectories deep inside Program Files. As if it wasn't hidden enough... Problem 6: By far the worst thing I've seen in a few months in a software product was a menu option called Utilities..Uninstall Preparation. They actually require you to select this before doing an uninstall, otherwise your registry will be filled with junk that will never go away. Oh, you'd have to read the UniQuest manual to learn about it (it's on page 106). While I can't confirm, I looked through the registry after their uninstaller was done and found a few references to "9.0", so it's possible this is what their new MIDIQuest version 9.0 product will do to you. If the MIDIQuest people are reading, they need to fire their UI developer, hire a UI expert and do what they say. They need to get real technical writers who are believers of "concise" straightforward documentation. And finally, they need to do usability tests with human beings who are also musicians, not Amiga** programmers from the '80s who have access to an FM radio which periodically plays synthpop. -Brian ** no disrespect to the Amiga. I owned one and loved it.
