Fixing USB problems
Fixing USB problems
2003-06-15 by Brian
Hello. I read a post where someone was having problems with Windows
XP seeing their XL-7. Here's an idea to try.
I had a similar problem with Windows XP 'seeing' one of my MIDI
interfaces. The solution was to sort of nudge Windows XP to look at
the USB ports again. Here's what to do:
Right click on My Computer and select Properties
Click on the Hardware tab, then the Device Manager button.
Expand the Universal Serial Bus controllers tree.
Double click on any subtopic that is a Hub or Host Controller.
Click on either the "Power" or "Advanced" tab (depending on which
type of device you clicked)
Click the Refresh button.
Repeat this for every item in the list.
What you are doing is forcing Windows XP to recheck the USB bus for
whatever devices are connected. In the case of my MIDI interface, it
solved the problem.
Unfortunately, I needed to do this every time I rebooted the
computer. Note, this problem is a fault of either Windows XP or the
motherboard you are using (in my case, Abit) -- not Emu.
-Brian
