RE : [xl7] Do anybody here...
2003-06-15 by portscan
you can
also depends on how good you play
but on the box's part, it works very well, realtime quantize...
you go to the trak you want to record into, then you hit record, then you play, then you listen (it's quantized), then you "unswitch" the record button.
then you choose another trak, you play.......
all what makes a big reason to get it.
  Sent: Saturday, June 14, 2003 11:04 PM
  Subject: [xl7] Do anybody here...
  Records grooves when playing live? Say you have a groove going and
  playing some leads with a keyboard controller and you play something
  you liked.... Is the record while playing back on the Emu station
  fluid enough to do that on the go while in a middle of a live set? or
  do you need to go back and edit in most cases to make the playback of
  the phrase right?
  thanks in advance.
Re: RE : [xl7] Do anybody here...
2003-06-15 by sincultura13
Damn, that is awesome... and in valuable tool, especially if you can
use the knobs to tweak it... I'm not too concerns about the realtime
quantizes as I am about the way it loops the phrase. How does it
work? You have to pre-choose how long its going to be? Or can you
just hit play and then loop on the go by choosing looping points?
thanks
--- In xl7@yahoogroups.com, "portscan" <guilt23@c...> wrote:
> you can
the record button.
>   ----- Original Message -----
>   From: sincultura13
>   To: xl7@yahoogroups.com
and
something
set? or
playback of
>   the phrase right?
>   thanks in advance.
