Virus stops playing notes using XL7 as seq thru SX
2003-06-14 by Justin Grimley
OK please bear with me for a minute while I describe my setup!! I am trying to sequence my Virus with the XL7. The XL7, Virus and other gear are hooked up to my PC running Cubase SX with a Midex 8 midi interface. I don't want to hook the XL7 directly up to the inputs on the Virus as I send other midi data to it from SX. So, I have created a template SX project with 16 midi tracks, each with an input transformer so they only recieve midi data on the correct channel, and each track has 'monitor' enabled. I set up the XL7 to respond to song start/stop and the tempo to 0(ext). Each XL7 track is set to ext only. I hit record on the XL7 and play in SX and recording starts on the XL7. This is where my problems start! The Virus all of sudden stops producing sound (although it still shows a note icon indicating midi input). I have to shut the Virus off and power it back up to hear anything. Any ideas? It is as if the XL7 seq is turning the Virus volume to zero. I suppose a better way to do this would be to purchase a midi merge box and have both midex and XL7 midi input to the Virus and bypass Cubase altogether. However, I was hoping that I could use the XL7 in this same manner to control all my other gear through the Midex, but still use Cubase for editing sequences. Sorry for the long post. Any help would be greatly appreciated. -Justin.
