How can I make it so the channel,track and preset advance when I use
the track advance button. I keep recording on the wrong tracks
accedently.
>>>Hehe, I used to do that too. Just make sure you're not incrementing
your tracks while in Preset mode. It only changes the MIDI channel of the
preset, not the actual track. Weird I know. <<<
Also, is there an undo quantise?
>>>If you're using the new OS and havn't saved since you performed the
quantize, you could use "Revert To Saved Pattern". It's the last option
in the Pattern Edit pages. Just save your pattern before doing any
quantizing, and then you can try them out before committing to any of
them. Or, you could use an external sequencer like Cubase too, which is
what I use as the options for quantizing are 100x more plentiful. <<<
Will it automatically undo when you re-quantise with a different value?
Can I record mute on/off messages in realtime song edit?
>>>Don't know. <<<
When I change the arpiggiator pattern on a preset it does not save with
it, am I doing it wrong?
>>>Is your arpeggiator set to MASTER? Did you resave the preset after you
made the change to the arp? <<<
Is there more rom expansions being released?
>>>Probably, since they just released the P2500. <<<
