Simple question about Multisetups
2003-06-11 by reconehelmut
I was told on this list that Multisetups are the way to go for
someone that is not using the internal sequencer in an XL7. So, for
all of my songs, I have setup a Multis that I call up before working
on the song in Sonar. This works okay but now I want to use this
peice of gear live and I cant for the life of me figure out how to
send a patch change message and get a multi to load - i have this
set for all the rest of my gear, its very simple - but there seems
to be a trick with the multis... please help.
rob
http://ph10.electropolis.com
Re: [xl7] Simple question about Multisetups
2003-06-11 by erik_magrini@Baxter.com
Yes, you can do what you want.  Check the list archives, this was talked
about quite extensively only a week or so ago.  I don't remember the
specifics (I don't use this feature), or I'd save you the trouble.
reconehelmut <reconehelmut@...>
06/10/2003 09:43 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Simple question about Multisetups
rob
Re: Simple question about Multisetups
2003-06-11 by steve_the_composer
--- In xl7@yahoogroups.com, "reconehelmut" <reconehelmut@h...> wrote:
> I was told on this list that Multisetups are the way to go . . .
In case you haven't found the help you need, here's the link to one
of my posts on multisetups
http://groups.yahoo.com/group/xl7/message/8906
Hope it helps.
2003-06-12 by reconehelmut
Thanks a lot. I understand what you've written here but it seems
like more of a workaround than the intended way to deal with multis.
In other words, it seems like there should be an easy way to send a
program change from a sequencer to an XL-7 that triggers a
multisetup load. Is there really no other way but this internal
trigger you described?
rob
--- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...>
one
> Hope it helps.
