I guess I'm beginning to think my XL-7 has a bunk USB interface.
I don't get yellow X's on the two unknown devices...I get 1 device,
labelled "unknown device", listed under "USB controllers", updating
the driver always results in windows complaining that the driver
selected (...USB0.inf) is not compatable with the device. I have the
two USB0 & 1 inf files, along with the actual .sys driver.
What type of device is the XL-7 supposed to be? (have the unknown's
shown up under "sound, video, and game controllers"?
thanks for the time...
-jk*
--- In xl7@yahoogroups.com, erik_magrini@B... wrote:
> Hmm strange that you're having problems with XP, works fine for
me. Try
> this:
> - Plug in the XL-7 to the USB port.
> - Go to Start -> Settings -> Control Panel -> System -> Hardware ->
Device
> Manager.
> - Open the drop down menu for Universal Serial Bus Controllers, and
you
> should see yellow X's on two of the unknown devices correct?
> - Double click on one of them and select Properties, then Update
Driver.
> - Choose the optiont hat lets you specify the location manually,
then
> navigate to the "USB Drivers" folder in your E-Loader Folder. Go
through
> all fo the prompts and it should install the driver and show up as
> "Interface 0". Repeat for the otehr unknown USB device, and it
shoudl show
> up as "Interface 1".
> Hope that helps!
> rEalm
> I've seen some people post about this, but haven't seen a solution
> or heard of one working.
> When i turn on the XL7, let it boot up, and THEN plug it into
> windows (as the directions say), windows xp will NOT correctly
> detect the device. Via MIDI, I have already upgraded to 2.0, and
> can run eloader. Eloader was not running while I tried to plug in
> the device to USB.
> Emu support has some canned response they used on me twice that
> includes "USB is only for sequence back up" and "please read the
> instructions and follow them exactly or you'll need to douse your
PC
> in bleach and reinstall windows". So I'm turning to you guys.
> I've tried this on several PC's (all, unfortunately, run winXP).
> Every one complains that an "unknown device" was plugged in, and
may
> have malfunctioned. Manual installs fail, because windows
complains
> the drivers I try to set (tried both usb0 and usb1 first) an
> incompatible with the device..I'm guessing that's because
> it's "unknown".
> But, I'm thinking that the device has some unique ID, (since
> subsequent install attempts happen so much faster than the first)
> and that I can edit the registry settings for it, so windows can
> match up the same strings that exist in the driver vs. what's
> detected.
> A.) Anybody got another solution?
> b.) What, EXACTLY, does windows XP detect the device as?
> thanx
> -jk*
> Your use of Yahoo! Groups is subject to
