Thank you very much for the help, I'll try what you said.
//Nifflas
--- In xl7@y..., Aaron Eppolito <aarone+xl7@e...> wrote:
> If you set the track to external, it will not save new info for
that track at
> tick 0. This includes program change, vol, pan, mix, arp, etc...
However,
> it will not erase existing messages (which would be there if you
saved it
> once when it was not external only).
> Two things you can do:
> 1. If you really don't want the XL-7 to transmit setup stuff, set
the track
> to external. If you've already saved it as both, you can set the
track to
> external, then erase the offending messages from the track (using
the ERASE
> EVENTS screen). Then, save it, and it won't send info on those
tracks
> anymore.
> 2. (Recommended) Set the track to external. Go into the list
editor and
> insert the commands to setup your external synth at tick 1. This
way, your
> external synth will always stay in sync with the current pattern.
> -Aaron
> nifflas@m... wrote:
> > I have some questions about the new OS... won't be able to try it
> > before the emu guys have repaired the XL-7.
> > When I selected a new pattern (OS 1.01), Program Changes, Volume
> > (CC7) and Pan (CC10) was automaticly sent to my external synth,
which
> > totally messed up the multisetups of the synthesizers...
> > The multisetups of the external gear already has information about
> > pan, volume and instrument, so I can see no reason why the XL-7
must
> > send this info.
> > Can such messages be blocked in the new OS, or will I have to buy
a
> > MIDI filter just to do this simple thing?
> > //Nifflas
> > To unsubscribe from this group, send an email to:
> > xl7-unsubscribe@y...
> > Your use of Yahoo! Groups is subject to
