Re: [xl7] NO sound output from P2500
2003-05-19 by erik_magrini@Baxter.com
Peter,
I'm sorry, but I'm flat out of ideas on anything else I could add to try
and fix your P2500 problem.  Perhaps you should try calling Emu's Service
Center  in the US, and see if they can help you out?  Their number is:
1-831-438-1921
Best of luck with your problem, sorry I couldn't help you more,
So far no luck on upgrading the o.s. to 2.0 (P2500)
Well I tried  downloading the  Patterns and songs  data but nothing seems
to happen (No midi  led light flickering.).neither on the MTP AV  and
P2500 module.
Well can you guide me and give the exact settings to be done on the
PROTEUS 2500 module   and also on the E-loader While downloading
songs/patterns from the e-loader to the P2500.
Whether  the proteus 2500 should be set to any mode ,pls let me know.
MIDI connections set  to :
MIDI    IN/OUT  of MTP  AV USB   going   into   MIDI    OUT /IN (A) Of
P2500 Module.
CONFIG:  P2 ,128mb ram,4 gb hard drive,Win 98 Se ,E-loader 1.1 ,Motu's MTP
 AV USB.
Waitng for your reply.
Thanks and best regards
Peter
2003-05-20 by Umesh Bhagwat
Dear Sir,
Thanks for your mail.
We have already contacted emu on the above issues and they will be
supplying  a replacement.
This is just for my  knowledge I just want to know some settings.
P2500 Module.
 AV USB.
Sorry for the trouble.
Peter
erik_magrini@... wrote:
>Peter,
>1-831-438-1921
>rEalm
>P2500 module.
>P2500 Module.
> AV USB.
>Peter
>To unsubscribe from this group, send an email to:
>xl7-unsubscribe@yahoogroups.com
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2003-05-20 by erik_magrini@Baxter.com
You don't need to change any setting on the P2500 itself, just select the
Pattern/song in E-Loader, and click on Download.  The P2500 will accept
and store the patterns and songs automatically.  The E-Loader installer
contains all the documentation on how to set up and use E-Loader.
2003-05-21 by Umesh Bhagwat
Dear Sir,
THANKS A LOT .
Sorry for the trouble...
once again thanks thanks.
Have a Nice Day
Peter
>rEalm
