pure phatt
2003-05-19 by sean deason
so I have the pure phatt rom newly installed and downloaded to Mo' Phatt patterns to the module. so how do I get the patterns to play the correct presets? I know the patterns are there, but i get "not installed" for all patterns. anyone know how to get my new patterns to address the new ROM? thanx sean deason
2003-05-20 by Aaron Eppolito
The Pure Phatt ROM is not the same as the ROM that's in the MP-7. Same samples, but different ID and different presets. Someone coverted all the presets to place in your user bank, but you'd have to point all the patterns there... -Aaron --- sean deason <seandeason@...> wrote: > so I have the pure phatt rom newly installed and downloaded to Mo' > Phatt patterns to the module. so how do I get the patterns to play > the correct presets? I know the patterns are there, but i get "not > installed" for all patterns. anyone know how to get my new patterns > to address the new ROM? __________________________________ Do you Yahoo!? The New Yahoo! Search - Faster. Easier. Bingo. http://search.yahoo.com
2003-05-20 by sean deason
thanks for the response. but the presets for the pure phatt rom were already on the rom when I installed it. its the *patterns* that arent working correctly. I downloaded the patterns from the net and downloaded them to the module using eloader, but the presets the patterns point to are showing "not installed". sorry I guess I wasnt clear about the problem I'm having. are the patterns and presets different on the Mo Phatt/MP-7 and Pure Phatt ROM? thanks again sean deason --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote: > The Pure Phatt ROM is not the same as the ROM that's in the MP-7. Same > samples, but different ID and different presets. Someone coverted all > the presets to place in your user bank, but you'd have to point all the > patterns there... > > -Aaron > > --- sean deason <seandeason@h...> wrote: > > so I have the pure phatt rom newly installed and downloaded to Mo' > > Phatt patterns to the module. so how do I get the patterns to play > > the correct presets? I know the patterns are there, but i get "not > > installed" for all patterns. anyone know how to get my new patterns
> > to address the new ROM? > > > __________________________________ > Do you Yahoo!? > The New Yahoo! Search - Faster. Easier. Bingo. > http://search.yahoo.com
2003-05-20 by Stu
I don't have a command station so forgive my ignorance, but don't you have to go into preset edit and select which pattern you want to go with that preset? Or is that what you're trying to do already? Regards, Stu
Sent: 20 May 2003 10:13
Subject: [xl7] Re: pure phatt
thanks again
sean deason
Same
all
all the
> patterns there...
> -Aaron
Mo'
play
get "not
patterns
> Do you Yahoo!?
Yahoo! Groups Sponsor
[Non-text portions of this message have been removed]2003-05-20 by Aaron Eppolito
--- sean deason <seandeason@...> wrote: > thanks for the response. but the presets for the pure phatt > rom were already on the rom when I installed it. Right, but those presets are not the same ones on the MP-7 ROM. > but the presets the patterns point to are showing "not installed". That's because they aren't there. You have Pure Phatt presets, and the patterns are looking for MP-7 presets. > sorry I guess I wasnt clear about the problem I'm having. Nope, you were very clear. =) > are the patterns and presets different on the Mo Phatt/MP-7 > and Pure Phatt ROM? Well, there aren't any patterns on the ROM (they come with the MP-7) but yes, the presets are different. You almost got it right. Pure Phatt == Mo'Phatt, and MROM == MP-7. Like I said before, you could download the MP-7 presets, but you'd still have to set every patterns' preset selections by hand. This could be a *very* arduous task for 128 patterns times 16 tracks. I suppose someone could write a tool to convert 0xBn 0x00 0x0F to 0xBn 0x00 0x00 in the SMF files (this would convert the bank select for the MP-7 ROM to the user bank). -Aaron __________________________________ Do you Yahoo!? The New Yahoo! Search - Faster. Easier. Bingo. http://search.yahoo.com
2003-05-21 by sean deason
wow! thanks Aaron! when you put it that way it's crystal clear :^) I completely get it now. I guess I'll have to settle for just the Mo Phatt sounds and forget the patterns. thanks for taking the time to answer my questions :^) sean deason --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote:
> --- sean deason <seandeason@h...> wrote: > > thanks for the response. but the presets for the pure phatt > > rom were already on the rom when I installed it. > > Right, but those presets are not the same ones on the MP-7 ROM. > > > but the presets the patterns point to are showing "not installed". > > That's because they aren't there. You have Pure Phatt presets, and the > patterns are looking for MP-7 presets. > > > sorry I guess I wasnt clear about the problem I'm having. > > Nope, you were very clear. =) > > > are the patterns and presets different on the Mo Phatt/MP-7 > > and Pure Phatt ROM? > > Well, there aren't any patterns on the ROM (they come with the MP-7) > but yes, the presets are different. You almost got it right. Pure > Phatt == Mo'Phatt, and MROM == MP-7. > > Like I said before, you could download the MP-7 presets, but you'd > still have to set every patterns' preset selections by hand. This > could be a *very* arduous task for 128 patterns times 16 tracks. I > suppose someone could write a tool to convert 0xBn 0x00 0x0F to 0xBn > 0x00 0x00 in the SMF files (this would convert the bank select for the > MP-7 ROM to the user bank). > > -Aaron > > __________________________________ > Do you Yahoo!? > The New Yahoo! Search - Faster. Easier. Bingo. > http://search.yahoo.com
