problems with loop section function
2003-05-16 by coscon23
just installed v2.0, everything seems fine but i can't get the loop
section function to work... xmix works fine...
when i push "tap" and "stop" simultanously, the stop button begins
flashing, but nothing happens on screen... btw, i'm using pattern
mode only..
any help appreciated!
Re: [xl7] problems with loop section function
2003-05-16 by Aaron Eppolito
You have to set a section.  Either use the screen in the pattern edit
menu, or press Tap+Select on the bar you want to be the start point and
Tap+Edit on the bar you want to be the end.
-Aaron
> mode only..
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
Re: problems with loop section function
thanx alot aaron! :-)
i was waiting for smthng to happen on the screen instead of searching
for the screen in pattern edit mode... doh!!!
now i'm at it... a very big thank you for implementing the
function... it's a godsend!!!!
edit
and
> -Aaron
loop
begins
> > mode only..
> Do you Yahoo!?
2003-05-19 by erik_magrini@Baxter.com
That's normal, the screen won't change.
05/16/2003 02:53 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] problems with loop section function
mode only..
