Bass heavy?
2003-05-14 by erik_magrini@Baxter.com
Getting the low end right is one of th hardest things about doing a good mix, because so many factors affect it. You have the speaker types and size, the room size, what materials are in the room, etc. Getting a good mix doesn't mean it sounds good at home 9though that can be part of it). The real key of a good mix, is that it translates well to other systems. Like you said, it sounds good at home, but elsewhere it sounds too bass heavy. This can be fixed with a few things: - Keep back ups of your song's project file, don't just say you're done and that's it. I usually need to go back at least a couple times and make some small adjustment to the bassline or BD levels to get them to sit well in the mix. - Learn your speakers and room. Sounds simple, but it takes a lot of time to do correctly, you need to listen to your favorite CDs again and again and compare how they sound in there with elsewhere.. If you know your mixes are bass heavy everywhere but your room, then maybe you need to compensate by lowering the bass levels until it sounds thin in your room. Again, remember the point isn't to make it sound good in one place, but to sound good everywhere. Compromises have to be made sometimes. - Use multiband compression during mastering. That way, it's very easy to adjust just the lowend, you can tighten it up, even use it as a simple EQ. - Try lowering everything below 30-40Hz when you're mastering. Even a fairly steep cutoff curve will leave enough frequencies here to be felt at the clubs, without muddying up the song when played back on other speakers. Also, I like to cut out the bass on all tracks where it's not critical. If you've got some strings, or leads, try cutting out everything below 100-200Hz. If it sounds weird without the info there, then slowly start adding back more until it sounds right. I also use the 30-40Hz trick on myu basslines while mixing, that can bring back a lot of headroom and clarity. rEalm for me personally i have a hard time laying bass in right. it always sounds good at my crib, or even in another room in the house, but when i burn to cd and listen to it in someones car, the bass is usually really deep and drowns out everything. sometimes cutting the resonance down on the sound helps, but i feel the bass loses its bassyness. i thought i may need to compress but everyone says add eq and compression lightly and as a last resort. any tips on getting deep bass that sits in a track and can stilll be heard even at low volumes? To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ [Non-text portions of this message have been removed]
