"Frozen Clouds" Final version and Notes
2003-05-14 by erik_magrini@Baxter.com
Ok, thanks to everyone that took the time to listen to the rough draft and
give me ideas.  After a bad spell of writer's block, it helps to know
you're at least on the right track again!  Anyway, after a couple more
marathon sessions working on it, the track is now done and available for
anyone that wants to take a listen:
http://rEalm.iuma.com  "Frozen Clouds"
The players:
Emu XL-7 - Provided all of the sounds except the intro pads and guitars.
This was originally a 16 measure pattern that I wrote to use in a
downtempo live set, though the addition of the guitar stuff changed it so
much that I'll need to find a way to mimic it in the XL-7.  The drums are
all doubled up inside the XL-7, a very easy procedure that makes a huge
difference in the way they sound.  Easy to do on the mc505 too!
Guitar - A custom-shop Ibanez S540FMTT running through an ADA MP2 midi
tube guitar pre-amp, with a Digitech TSR-24s on the effect sends.  A
really basic tone, with a hint of reverb and delay added at this stage.
Access Virus KC - The pads in the intro are just two held chords from the
Virus, using my own patches from a forthcoming User Soundset I'm doing.
Cubase SX - All of the arranging and recording took place with this.  Plug
ins that got heavy use: TL-Audio's EQ-1, PSP24 Lexicon Delay emulator
(what a kick ass plug in!), Antares Tube (one of my new favorites), Ohm
Boyz Delay, and SX's Dynamics.
Wavelab 4 - Used this one for the mastering, with the Waves Linear
Mastering plug ins: LinLowBand EQ, LinMB, and L2.
RE: [xl7] "Frozen Clouds" Final version and Notes
Yes, mainly XL-7 sounds, but at this point they're so wrapped up as part
of the SX arrangement, it would be (as you say) probably not to easy to
do.  Besides, last time I did a key change, my landlord got mad when I
didn't give him a copy ...
Are most of these XL7 sounds?  If so shouldn't be too hard?
2003-05-14 by Andre Lewis
Ok, so I finally listened to it, and it sounds gret, great sounds good job on
the beats!  After listening to it though I get the feeling it wants to go into a
key change after the first main part (around 2:00 min) maybe up a third.  Don't
know how possible that is.  Are most of these XL7 sounds?  If so shouldn't be
too hard?  You'd probably have to change the arrangement a bit too, so maybe it
isn't worth it.  Sounds good tho, even over my crusty laptop speakers... ;)
Andre
Sent: Wednesday, May 14, 2003 4:57 AM
Subject: [xl7] "Frozen Clouds" Final version and Notes
The players:
midi controller?
2003-05-14 by Chris gutierrez
I plan on buying a midi controller to work with my xl-7 and my roland sp-505. i was wondering if anyone knew how welll xl-7 will work with a midi controller, and if anyone has any recommendations on midi controllers
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
Ah I can see you are getting warmed up! me I'm thinking whether it's worth the
hour of sleep I will get... Perhaps I should stay up . . . the sequencer .. . .
it's calling to me . .. .. .
Sent: Wednesday, May 14, 2003 8:14 AM
Subject: RE: [xl7] "Frozen Clouds" Final version and Notes
