Hi there,
Does anybody know
1. if you can assign a certain riff to different presets?
2. if you can record a riff in a pattern? Or copy it to a pattern?
There are some nice drum grooves I´d like to use and transform in a
new pattern.
Anybody?
Heinrich
Hi,and thanks for answering, Jonathan,
are you sure?
I checked that in the manual as I cant get hold of my mp-7 right now:
In the arp section they talk about factory 200 pattern and 100 user
pattern you can assign. But in the appendix you will find a list of
362 riffs. So I doubt the patterns are the same as the riffs you will
get when you use the audition button.
Any Comments about that?
Heinrich
--- In xl7@y..., "Jonathan El-Bizri" <sserendipity@n...> wrote:
> Does anybody know
> Yes, it's all in the preset. I think it's under the arps section.
a
> >new pattern.
> You need to take the riff out - either with an external sequencer,
or by plugging the midi out into the midi in.
are you sure? I checked that in the manual as I cant get hold of my
mp-7 right now: In the arp section they talk about factory 200 pattern and
100 user pattern you can assign. But in the appendix you will find a list of
Any Comments about
that?
I believe, (and I have neither the manual nor my xl in front of me, that
the patterns refer to the arpegio patterns, while the riffs refer to the
audition riffs. You can assign both to each patch.
