Re: [xl7] FW: [IBGEEK] Re: Single cycle loops
2003-05-06 by erik_magrini@Baxter.com
Gracias!
"Andre Lewis" <andrel@...>
05/06/2003 10:54 AM
Please respond to xl7
        To:     "Xl7@Yahoogroups. Com" <xl7@yahoogroups.com>
        cc:
        Subject:        [xl7] FW: [IBGEEK] Re: Single cycle loops
I just had to forward this to those that aren't on IBGeek - This is a
great way
to simulate an analog synth method with a sampler
--- From Aeon ---
a good way to get PWM with static sampled waves is to sum a saw and an
inverted
detuned copy of itself...change the detune and you will change the PWM
rate.
2003-05-06 by Andre Lewis
I just had to forward this to those that aren't on IBGeek - This is a great way
--- From Aeon ---
a good way to get PWM with static sampled waves is to sum a saw and an inverted
detuned copy of itself...change the detune and you will change the PWM rate.
2003-05-06 by robotchas
This is actually one of the reasons I was disappointed to hear that
the XL-7 could not reverse samples (reverse a single-cycle saw and
you get an inverted saw). The Morpheus has at least one sawtooth
waveform that happens to be inverted (though it's not needed b/c the
Morpheus can reverse samples), so I'm hoping the XL-7 will have one
as well - since it can't do real PWM this makes for a passable
imitation useful for pads. Anyone know?
a great way
> --- From Aeon ---
an inverted
PWM rate.
