Re: [xl7] e-loader
Re: [xl7] e-loader
2003-04-30 by erik_magrini@Baxter.com
it changed all the songs ALL INCLUDING THE EMU presets ..the patterns
remained but the presets were all changed ..
>>>Since E-Loader has nothing to do with Presets, it can't be that.  After
you reloaded the pattern, did you try doing a revert to saved for that
Pattern just in case? <<<
1)can e-loader save all the patterns in  one shot  ?
>>>Yes, just highlight all of the Patterns you wish to save, and then it
will let you pick the folder to save them too.  You cannot save them as
one file though, it will save them all individually. <<<
2) what information is saved on the e-loader files ?
>>>The MIDI Pattern files save all of the information concerning the
pattern setup; effects types and send amounts, preset assigments, pattern
name, length, track/channel assignments, etc. <<<
3)how to i prevent this from happenning in the future ?
>>>Before you use E-Loader to back up your patterns to the computer, you
might want to do a "revert to saved" just to make sure that all of you
presets are assigned correctly. <<<
