I would check internal connections. Particularly any chip that sits in a
socket.
WARNING, if your not comf0ortable opening the box or really don't know what
your doing, ask someone who is.
Oen the unit. Touch the powersupply to release any static electricy you may
be charged with.
> Thanks Reek for the advise, but I have to suggest that when opening any
electronic device you DO NOT touch the power supply. The good news is the
xx-7's have power supply covers, but many products do not. Even after being
turned off, many power supplies will carry their charge. DANGER, you will
be shocked.
sean at e-mu
"psychogroove1
" To: xl7@yahoogroups.com
<Reek@SoundsAm cc:
azing.com> Subject: [xl7] Re: Alarming behavior...
04/29/2003
08:32 AM
Please respond
to xl7
socket.
be charged with. Press firmly any chip that sits into a socket. You'll most
likely
hear minute sounds ad the chips snug up with the sockets.
If you move equippment around frequently, the connections can become a
little loose. Vibrations from banging on the buttons and expansion from
heat
as the unit warms up can compound these problems and reveal intermittent
problems.
I used to work with lots of touring bands and this was a problem from the
gear
ridding in trucks around the country and around the world. I even had
problems with some of my gear from the move from LA to Seattle. More than
50% of the problems I've seen with all gear can be fixed this way.
Reek
--- In xl7@yahoogroups.com, quazar <quazarproductions@p...> wrote:
> or all EMU's are starting to fall apart after a while....
> op 29-04-2003 15:03 schreef erik_magrini@B... op
> erik_magrini@B...:
> Does this only happen while you're playing out? I had very some weird
> issues last week during my live set too:
> - 16 measure patterns looped for 32 measures, even though 17-32 were
> blank.
> - Patterns wouldn't switch even though they were queued correctly, the
> current pattern would play indefinitely.
> - Pressing Edit+Track Mute to select a new track would cause the XL-7 to
> play random sounds not from the Preset assigned to that channel.
> - Lots of other stuff that killed the set.
> Never seen any of these before, and haven't seen them since no matter
what
> I try. After some talks with Emu, we are both inclined to agree it was
> most likely issues with the mains power at the venue, it was probably too
> low. I know I'm buying one of those cheap USB power supplies ($40) from
> Office Depot to remedy the situation in the future, might want to look
> into that as well.
> rEalm
> Hi all... my XL is beginning to develop a habit that makes me worry a
> bit...
> I'll be playing out, editing a pattern or a song, and as I push
> various buttons, my display begins to fritz out... It begins to
> slowly display random characters... they don't look like random parts
> of the LCD lighting up, but maybe some sort of foreign alphabet?!
> And to top it off... I think it's getting more frequent, and crashing
> faster with each occurrence! That could just be me getting gear-
> paranoid though...
> Yahoo! Groups Sponsor
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/> .
> Deze e-mail is door E-mail VirusScanner van Planet Internet gecontroleerd
op
> virussen. Op http://www.planet.nl/evs <3D"http://www.planet.nl/evs">
staat
> een verwijzing naar de actuele lijst waar op wordt gecontroleerd.
