seamless loops while recording
2003-04-28 by kaniner2003
I am a new user and I'm having difficulty trying to record a bass line. (or any seamless loop track) My goal is to record a realtime bass line that repeats itself without a pause after, say 8 bars. I hit record and try to begin playing right when the clock starts. I play for 8 bars and try to stop at the end. When I play it back there is usually a pause in the performance. What I want is a seamless loop. I don't get it? How do I record a track that starts and ends at the 1.1 and 8.4? Thanks for your time! Darren
2003-04-28 by biz@groovetronica.com
Not to be flippant, but have you tried turning on the metronome? bIz
Sent: Monday, April 28, 2003 11:09 AM
Subject: [xl7] seamless loops while recording
the 1.1 and 8.4?
Darren
Yahoo! Groups Sponsor
[Non-text portions of this message have been removed]2003-04-28 by Scott Chiaravalloti
kaniner2003 <Skymountain1@...> wrote: <<<I hit record and try to begin playing right when the clock starts. I play for 8 bars and try to stop at the end. Thanks for your time!>>>> Darren, Turn the metronome on if you don't have a drum track already in place. Set count-in to either one bar (4 beats) or two bars (eight). Begin playing after the count-in. Or, assuming you have software 2.0, you could scroll past he two bar choice and set it to "first note record" - a single note icon indicates that option. The recording will begin when you hit the first note. Play freely until the end of the eighth measure. No need to stop the sequencer exactly at 8.4. If you have the pattern length set to eight bars just be sure to stop playing before bar one begins again. Then hit stop(twice). Listen to it. If it isn't tight enough re-do it or try quantizing it a bit 10-50%. If you leave swing set to the default 50% it won't add any (swing, that is). And, if you try the quantize be sure to set it a note value that makes sense for the riff you have laid down. 16th note quantize at about 20% might tweak things just enough for your bass-line to sound "on" but natural. You will use quantize quite a bit before knowing exactly what you want to get out of it. Also, of course, you could grid sequence or step sequence. Loads of trial and error in this area will probably be required but you will be amazed at what you can pull off. If you are a musician of some sort already then it will just be a matter of learning how to use the machine. Hope some of this helps. Scott Yahoo! Groups Sponsor To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Do you Yahoo!? The New Yahoo! Search - Faster. Easier. Bingo. [Non-text portions of this message have been removed]
2003-04-29 by erik_magrini@Baxter.com
Better yet, if you set the two bar count in to the "note" symbol, you can now press Play+Record to enter Replace Record mode. Recoding will start when you play the first note, and stop AUTOMATICALLY at the end of the 8th measure in you case. That way you don't have to worry about trying to time your playing to end precisely. rEalm Turn the metronome on if you don't have a drum track already in place. Set count-in to either one bar (4 beats) or two bars (eight). Begin playing after the count-in. Or, assuming you have software 2.0, you could scroll past he two bar choice and set it to "first note record" - a single note icon indicates that option. The recording will begin when you hit the first note. Play freely until the end of the eighth measure. No need to stop the sequencer exactly at 8.4. If you have the pattern length set to eight bars just be sure to stop playing before bar one begins again. [Non-text portions of this message have been removed]
