Index last updated: 2026-03-31 01:49 UTC
Stuck note
Stuck note
2001-11-26 by Kamy
I get stuck notes by playing some presets with longer duration(like kit:K-6
Chorus)  from my kayboard on XL-7.
Do you guys know any way out?
Kamy
Logic/mac
Re: Stuck note
2001-11-26 by albert_thorn@kickassmartians.com
I sometimes get stuck notes when using the XL7 rubber keypads as
well.  I think it is a hardware problem with the pads themselves
because it only happens when I play the pads very quickly.  It
usually happens when I barely make contact with the pad to trigger
the note.  I haven't had any trouble with stuck notes when triggering
with an external keyboard.
The work-around is to always press down hard on the pads.  If you do
get a stuck note, just press that pad again and it will send
the "note off" signal to kill the hanging note.
- A.
kit:K-6
> Kamy
> Logic/mac
Re: [xl7] Re: Stuck note
2001-11-26 by Kamy
It's funny sometime it does sometimes not.
I trigger it from an external keyboard.
It doesn't completely stuck , it is just the aftertouch, which gets stuck
for ca. 1/2 sec and then it goes over to note off.
K.
> - A.
> kit:K-6
>> Kamy
>> Logic/mac
> ------------------------ Yahoo! Groups Sponsor ---------------------~-->
> Universal Inkjet Refill Kit $29.95
> Refill any ink cartridge for less!
> Includes black and color ink.
