Multisetups vs. Direct Pattern Access
2003-04-26 by robotchas
Does loading a multisetup interrupt the sequencer or is it possible
to load one while the sequencer is playing?
For instance, if I have a pattern running and I load a multisetup
which has the exact same settings for preset, volume, pan, and so
forth but has different Direct Pattern Access assignments, will I
hear a hiccup or will the multisetup load seamlessly?
Basically I'm wondering if it's possible to change DPA assigns
throughout a couple-hour set without stopping the sequencer...
And are we ever going to see the full sysex spec for the Command
Stations?
