Sent: Tuesday, April 22, 2003 12:49 PM
Subject: Re: [xl7] recording from SPDIF output?
What does quantisation noise sound like? How can I
recognize this?
--- Aaron Eppolito <synthesis77@...> wrote:
> --- kmusard <kmusard@...> wrote:
> > I know that it is good recording practice to get
> the hottest signal
> > from the source without clipping to get a good
> singal to noise
> > ratio. Is this required for SPDIF? I am thinking
> that since the
> > connection is digital I should be able to record
> from the MP-7 then
> > normalize the recordings on my PC without boosting
> noise.
> Well, you're correct in that you won't be boosting
> analog white noise
> (as there is none in digital) but you will be
> boosting quantisation
> noise. However, as S/PIDF is at a much higher bit
> depth than most
> media these days, you should be fine. Normalizing
> the S/PDIF will
> *always* yield quieter results than recording the
> analog mains because
> the same digital signal that feeds the S/PDIF feeds
> the D/A converters
> (don't quote me on that, but I'm pretty sure).
> Therefore, all you're
> doing by recording the analogs very hot is
> performing analog
> normalization instead of diginal normalization, with
> unneeded D/A and
> A/D stages!
> -Aaron
> __________________________________________________
> Do you Yahoo!?
> The New Yahoo! Search - Faster. Easier. Bingo
> http://search.yahoo.com
Do you Yahoo!?
